Old 05-26-2018, 07:37 AM   #1
Magoo2
Default Steering box gaskets
Getting ready to start up my 31 truck after many years. I'm changing all fluids engine,trans,differential,steering box. Filled the steering box yesterday and noticed it's leaking this morning. May eventually have to pull and rebuild. Has anyone just replaced the gaskets without removing the steering box.
Magoo2 is offline   Reply With Quote
Old 05-26-2018, 07:42 AM   #2
burner31
burner31's Avatar
Default Re: Steering box gaskets
If it's leaking from around the light switch you can change that without pulling...but if it's leaking from the sector housing you will have no choice but to pull the box.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 05-26-2018, 01:36 PM   #3
1931 flamingo
1931 flamingo's Avatar
PennRite steering box lube.........................NO leaky.
Paul in CT
Old 05-27-2018, 08:56 AM   #4
Gary WA
Gary WA's Avatar
Where,s the leak?
www.whidbeymodelaclub.com
Gary WA is online now   Reply With Quote
Old 05-27-2018, 11:16 AM   #5
CWPASADENA
CWPASADENA's Avatar
Paul in CT
X2
Chris W.
CWPASADENA is offline   Reply With Quote
Old 05-27-2018, 11:48 AM   #6
duke36
the large cork can fail over time requiring pulling the housing. Someone mentioned in a post to buy a washer with a rubber or sealed insert for the side sector screw and nut. O' rielly's or Napa has them in a pack of 2. Also, some prefer staying with the bronze sector bushing which may not leak as much as the needle types. Adding an o ring or seal at the frame can help requiring pulling the housing also.
duke36 is offline   Reply With Quote
Thread Tools
Display Modes
