11-04-2011, 04:50 PM | #1 |
engine knock
I have a 24 stud that has a slight knock when under a load at low rpm's. It almost sounds like pre ignition knock. I removed each plug wire one at a time and the knock did not go away. I also used a long screwdriver to listen with, but could not hear anything abnormal. Any idea what could cause this? The distributor was rebuilt by one of the vendors listed on this site. Thanks
11-04-2011, 05:33 PM | #2 |
Re: engine knock
If it has a vacuum brake, try increasing the tension a small amount. Test drive and adjust until it is gone (if it is spark knock). If it is a later distributor, back off the initial advance.
11-04-2011, 05:37 PM | #3 |
Re: engine knock
Exactly, how does a vacuum break work and how do you know when it needs to be adjusted? On my '37 Ford it seems to run well but maybe it could do better adjusting the break.
11-04-2011, 05:42 PM | #4 |
Re: engine knock
The vacuum brake slows the advance when accelerating(low vacuum). There is a piston that is held back by manifold vacuum. When you accelerate, there is spring that forces the piston against the advance plate, slowing it's movement. Back the screw out until you get pinging when accelerating. Tighten a little and you have it
11-04-2011, 07:38 PM | #5 |
Re: engine knock
If it is not in the ignition, then is probably a rear main bearing. Marv
11-05-2011, 08:05 AM | #6 |
Re: engine knock
www.fordcollector.com |
11-05-2011, 10:30 AM | #7 |
Re: engine knock
I did remove the fuel pump rod to compare the length with a nos rod I have, but did not change the fuel pump. My next step will be to change out the distributor and fuel pump and see what happens. The engine was rebuilt several years ago but only has about 500 miles on it, so should I drive it and see of the knock gets louder before I pull it?
