Old 02-12-2020, 04:26 PM   #1
Werner
Werner's Avatar
Default Nice Gasoline Filter
N'Abend miteinander!
Does anyone have a tip for an good antique-old gasoline filter? There are nice filters for Harley D., but they are much too coarse in the strainer and are of no use.
The mounted plastic filter (micronic paper) works very well, but unfortunately ugly for a classic car.
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Honda CB 450 K 1, 1968
Hercules Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
Old 02-12-2020, 04:48 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Nice Gasoline Filter
No, But get rid of rubber hose/filter and put on stock style gas line. If your tank is clean and have a pencil filter in gas tank shouldn't need that filter.plus the firewall filter
www.whidbeymodelaclub.com
Old 02-12-2020, 04:54 PM   #3
Werner
Werner's Avatar
Thank you, Gary. But no, the tank is unfortunately not clean. There is some rust in it, but also old tough residues that only dissolve very slowly.
Therfore because of this, I unfortunately have to use a fine gasoline filter in the line.
Werner
Citroen 11 CV, 1947
Old 02-12-2020, 05:19 PM   #4
Sunnybrook Farm
Sunnybrook Farm's Avatar
If you have a glass sediment bowl, a NAPA 3039 filter will fit right at the top where the brass screen is. I got one today for a little over $6. The guy said it showed as being for some GM products back in the early 60s so there wasn't any in the store but they got one shipped in next day. It looks like it is made to be there.
Sunnybrook Farm is offline   Reply With Quote
Old 02-12-2020, 06:06 PM   #5
Synchro909
Synchro909's Avatar
I run a disposable filter similar to that on each of my cars, rubber connections and all. I figure a flexible section in the fuel line reduces the possibility of a fracture, hence reduces the risk of fire. I also use FAMs so the motor moves a bit and without the flexible section, all that movement has to be taken by the fuel line and it will eventually fail, IMO. 80,000 miles and no problem.
For the first half of our life we trade our health for wealth. For the second half, we trade our wealth for health.
Old 02-12-2020, 06:20 PM   #6
whirnot
whirnot's Avatar
I too run one inside the sediment bowl.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 02-12-2020, 07:26 PM   #7
Conaway2
Conaway2's Avatar
Interesting Synchro....I run a similar filter arrangement as well, but just replaced the rubber tubing with a steel line for the same reason - worry that vibration would lead to tubing failure. Maybe I should rethink.....
Jim
Conaway2 is offline   Reply With Quote
Old 02-12-2020, 08:33 PM   #8
Tacoma Bob
Tacoma Bob's Avatar
1959 General motors. (Cadillac) I have run them for years.
Tacoma Bob is offline   Reply With Quote
Old 02-12-2020, 08:55 PM   #9
Mulletwagon
Mulletwagon's Avatar
Went this route -
https://www.brattons.com/glass-sedim...el-filter.html
Mulletwagon is offline   Reply With Quote
Old 02-12-2020, 11:19 PM   #10
daveymc29
daveymc29's Avatar
I'm with Gary in No. 2. I have never had much luck with the other filters. Well that's not entirely true if you count bad luck. Had to be hauled home twice before I removed the filters except the pencil filters inside the tank attached to the shut off valve. Helps me pick up clear fuel from higher up in the tank. Some forego the filter and just use a small length of tubing inside the shutoff. I prefer the pencil filter and haven't experienced any clogging in the carburetor since I replaced the filters in the line with the one filter in the shut off. Your results may vary if the tank is extremely rusted.
daveymc29 is offline   Reply With Quote
Old 02-13-2020, 01:15 AM   #11
Brentwood Bob
Werner, does the filter have a direction of flow? Seems to me it should be 180 degrees switched so the tapered end would discharge into the carburetor?
Maybe it doesn't matter.
Brentwood Bob is offline   Reply With Quote
Old 02-13-2020, 06:18 AM   #12
Werner
Werner's Avatar
Guten Morgen.
My car's year of construction is 1928 with the original iron bowl. I will use copper for the fuel line, it is elastic and does not tend to crack when vibrating. At this time there is brass.
My problem is that I need a very finely screened filter. The plastic-paper-filter in the past was very dirty after 3000 mls. But such a plastic thing doesn't look good for this classic car. -
Bob, yes, the filter is mounted the right way round. The large filter area should always pointing towards the inlet.
Thank you for the hints!
Werner
Citroen 11 CV, 1947
Old 02-13-2020, 10:06 AM   #13
Bob Bidonde
Bob Bidonde's Avatar
The original Ford sediment bowls without add-ons work very. Any additional filter in the system is a flow restriction.
Bob Bidonde
Old 02-13-2020, 10:34 AM   #14
katy
katy's Avatar
What year did Ford switch from the cast iron to glass sediment bowl?
Play it again Sam.
Old 02-13-2020, 10:56 AM   #15
rocket1
If you think you need an xtra gas filter the ones on riding lawn mowers are small.
rocket1 is offline   Reply With Quote
Old 02-13-2020, 11:28 AM   #16
100IH
Copper is more likely to harden and crack than steel line.
100IH is offline   Reply With Quote
Old 02-13-2020, 12:01 PM   #17
GPierce
GPierce's Avatar
Mine like that was letting fine particles into the carb and eventually stopping up the jets. Installing the NAPA 3039 solved the problem. I drained the tank thru that filter and it pissed a steady stream.
I check it occasionally and changed it when necessary. Takes 5 minutes. Much easier than changing the finger screen inside the tank which requires dissembling the plumbing after draining the tank.
I know, I'm a heretic for removing the finger screen but it got stopped up on a tour and was a PITA on the side of the road.
GPierce is offline   Reply With Quote
Old 02-13-2020, 01:23 PM   #18
ryanheacox
ryanheacox's Avatar
I was thinking the same thing. Maybe Werner was referring to copper-nickle line? That stuff doesn't work harden like straight copper and it bends beautifully.
Old 02-13-2020, 01:33 PM   #19
Ernie Vitucci
Good Morning all...Back in the 60's an old mechanic working on my Model A changed my car to the glass bowl filter on the fire wall and inserted a big magnet that covered the bottom of the glass bowl...it seems to trap what ever comes out of the tank and I can look into the bowl and see when to open the filter and clean the red rust/stuff off the magnet, wipe out the bowl and put it back together...Ernie in Arizona
Old 02-13-2020, 01:44 PM   #20
54vicky
54vicky's Avatar
in Werners case I think form follows function.I second the nicopp for lines if going that direction
54vicky is offline   Reply With Quote
