Old 02-09-2020, 08:49 PM   #1
30-9
Default NGK plugs
Hi gents
Anyone know what the difference is between B4-L & B6-L for NGK?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 02-09-2020, 09:00 PM   #2
Phil Gillespie
Phil Gillespie's Avatar
Default Re: NGK plugs
Originally Posted by 30-9 View Post
Hi gents
The heat range. B4-L will be a hotter plug than the B6-L.
Phil NZ
Phil Gillespie is online now   Reply With Quote
Old 02-09-2020, 09:51 PM   #3
Bored&Stroked
Bored&Stroked's Avatar
Phil has it right . . . I can't see you running the B4-L . . . I run the B6-L plugs is just about every engine that isn't supercharged (and where this is the correct plug length for the heads I'm running).
Some guys buy late heads (like Edelbrocks), then they buy the old short reach plugs (like the B6-L) - which are completely WRONG for the later Edelbrock heads that utilize 3/4" reach plugs. Just pulled a set of Autolite 216's out of a set of late Edelbrock heads this weekend - and put in the correct plugs.
Old 02-10-2020, 07:22 AM   #4
30-9
Thanks Gents
I’m running stock heads. I think the guy in the store mistakenly gave me B4. I didn’t realize it until after install and running them over a week. What side affect will this have? Should I eat the $30 and replace?
Thanks - 30-9
1939, 1940
Old 02-10-2020, 08:23 AM   #5
flathead48
flathead48's Avatar
B6-L the same as 3212 with 7/16 reach, I have been using autolite 216 but I thought I would try the ngk in my stock 48. Thanks, Rick
flathead48 is offline   Reply With Quote
Old 02-10-2020, 08:39 AM   #6
JSeery
JSeery's Avatar
Information on NKG site: https://www.ngk.com/learning-center/...or---do-i-need
It depends on several factors, but too lean a condition or too hot a plug can result in engine damage.
JSeery is online now   Reply With Quote
Old 02-10-2020, 10:26 AM   #7
Phil Gillespie
Can testify to running too hot a plug. They were B4-L along with a couple of other factors destroyed a piston, detenation.
I would opt for correct plugs B6-L. Cheap fix again for peace of mind as opposed to engine rebuild.!!
Phil NZ
Old 02-10-2020, 10:32 AM   #8
30-9
Thanks. Totally agree, I pulled them out. Glad I asked
Thanks - 30-9
1939, 1940
Old 02-10-2020, 10:34 AM   #9
flathead48
flathead48's Avatar
I checked the plugs and they look a little foul.(black) I don’t know if it is because I run it once a week at fast idle until it reaches normal temperature and than shut it down or if the 216 are too cold.
Old 02-10-2020, 10:40 AM   #10
Bored&Stroked
You can't check plugs by just running the engine, idling it, driving around town, shutting it down and looking at them - they will always be black/sooty.
You have to run the car on the highway, under medium to heavy acceleration, cut the engine and push the clutch in. Then - coast to the side and check them. Anything else is a waste of time.
Old 02-10-2020, 10:47 AM   #11
V8 Bob
V8 Bob's Avatar
I switched from B6Ls to B4Ls many years ago to minimize plug fouling, but I run straight tripple 97s along with a pretty radical cam.
Old 02-10-2020, 04:56 PM   #12
Ziggster
I'll be using the NGK B-6L as well for my mostly stock motor. Only reason though to use it vs the Autolite 216 was the fact that it has the removable terminal nut for use with hook style plug wires which is what I'll be using.
Ziggster is offline   Reply With Quote
Old 02-10-2020, 05:58 PM   #13
Biggles
Biggles's Avatar
NGK part number key:
https://i.postimg.cc/PxyzPyk3/NGK-part-number-key.jpg
Biggles is offline   Reply With Quote
Old 02-10-2020, 06:10 PM   #14
flathead48
flathead48's Avatar
Thanks to all for the info, I apologize if I hi jacked this thread, was not my intend. I was just trying to be sure I was trying the right plug. Thanks again, Rick
Old 02-11-2020, 06:09 AM   #15
flatford8
flatford8's Avatar
I’ve had a few of the 216’s come apart......in the spring I’m switching to something different....Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 02-12-2020, 09:04 AM   #16
Automotive Stud
Automotive Stud's Avatar
I prefer the hotter B4L plugs, but all of my flatheads have aftermarket cams and multiple carbs, so it helps keep them cleaner.
Since you already put them in the car I'd check them for signs of being too hot, like a white chalky plug, if it's fine I'd just run them.
Automotive Stud is offline   Reply With Quote
