Old 02-09-2020, 12:15 AM   #1
rehpotsirhcj
rehpotsirhcj's Avatar
Default 35-36 rear trans mount. Source for rubber ring?
I‘m putting together a parts list for a toploader rebuild, my winter project. I have the 48-5089 rear mount which is clean and ready to go, but the rubber was hashed.
Replacements include both the steel mount and the rubber bushing, but the gauge looks thinner, and it’s $50 when I only need $10 worth of rubber to go with my better quality stock mount.
Anyone have a source a part no. for just the rubber or the best quality of full replacement?
Thanks much,
-Chris
rehpotsirhcj is offline   Reply With Quote
Old 02-09-2020, 02:42 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: 35-36 rear trans mount. Source for rubber ring?
The only way to get it perfect is too have an original ford stamped steel piece shipped off to someone putting new rubber on it...
The aftermarket ones are as always a gamble...that it worked great last time doesn´t mean they now have the same supplier...sadly how things are today...
Old 02-09-2020, 03:53 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
I've never seen the rubber part available separately, but even at my age there's plenty I've never seen. If you or anyone else reading this post, knows of, or finds a source for those, please post it here.
John
Old 02-09-2020, 04:16 AM   #4
flatheadmurre
You send off the prepared steelpart to a company vulcanizing new rubber to it.
Today you could probably make a mold and poor uretan on it yourself...just have to get the shore(hardness) of the polyurethane right...
Old 02-09-2020, 09:07 AM   #5
Kube
Kube's Avatar
[QUOTE=rehpotsirhcj;1850150]I‘m putting together a parts list for a toploader rebuild, my winter project. I have the 48-5089 rear mount which is clean and ready to go, but the rubber was hashed.
Thanks much,
-Chris
Chris, I have purchased two of these from Mike Driskell in the past year. Both were very nice and a perfect fit.
Old 02-09-2020, 11:21 AM   #6
JM 35 Sedan
I've thought of trying something like that just to see how well I could make that work. If I still worked at my last employers company, I could get the guys in ours model shop to help with something like that. They could make prototype molds for anything conceivable.
John
Old 02-09-2020, 02:04 PM   #7
flatheadmurre
Originally Posted by JM 35 Sedan View Post
I've thought of trying something like that just to see how well I could make something like that work. If I still worked at my last employers company, I cold get the guys in the model shop top help with something like that. They could make prototype molds for anything conceivable.
Urethane would probably poor just fine into a latex mold.
Get hold of a good aftermarket trans mount and make a latexmold from that...
Old 02-10-2020, 12:26 AM   #8
rehpotsirhcj
Thanks guys, appreciate the info. I’ll check out Mike Driskell‘s site.
Old 02-10-2020, 12:00 PM   #9
Viv W
The rubber piece will not be available seperatly because it HAS to be vulcanized to the metal plates.
Taking your old plates to someone to redo it for you will cost more than 50 bucks, plus if it is not right, then it is a big job to take it out and redo the job.
I bought my replacement from Mac's and it fitted and looked right. Spend the 50 bucks, don't mess around.
Viv W is offline   Reply With Quote
