02-25-2018, 11:13 AM | #1 |
1931 v8 clutch finger adjustment, how?
I have read all of Toms articles and done v8 searches but I cant find what I need.
Is the adjustment done approximately the same way on a v8 clutch? And is the 5/8 inch still the correct number to use for a v8 clutch? The engine is out of the car. |
02-25-2018, 11:48 AM | #2 |
Re: 1931 v8 clutch finger adjustment, how?
Which "V8" clutch are you using? ----from Ford clutch/trans book
9" -- 11/16, .340 gauge plate (clutch disc thickness compressed) 10" -- 15/16, 295 gauge plate 11" ---7/8", .365 gauge plate the gauge plate takes the place of the clutch disc, it you are using a clutch disc rotate disc 1/3 turn reassemble and recheck to elimenate clutch disc thickness variation or do you mean the early V8 clutch that was baisically the same as "A", or a 60hp?? |
02-25-2018, 05:57 PM | #3 |
I hound a picture
03-01-2018, 06:51 PM | #4 |
