08-14-2011, 07:31 AM | #1 |
Help removing sleeve 37 Ford PU
I need to know how to remove the sleeve and grease seal from the torque tube for the 1937 Ford PU driveshaft. Thanks
08-14-2011, 04:42 PM | #2 |
Re: Help removing sleeve 37 Ford PU
I have not replaced one of these in a long time but believe I used a old screwdriver blade to colapse it. Model T's have bearing shells like this for inner and outer axle bearings and there is a special tool, tube with a spring loaded button that you can slide in there, pop the button into a notch in the shell, twist and pull the shell out. Do not remember if the T. Tube sleve has a hole or notch in it but that would be a good too for someone to make if it does.
08-14-2011, 06:42 PM | #3 |
Jack |
