Old 01-17-2020, 12:45 PM   #1
jiw1
Default crab distributor
got this (what looks to be a)rebuilt crab distributor and it seems to be ok except for the points do not look to be square or inline,will this have any effect on the performance of the distributor?i attached three pictures.i hope you can see what i mean.thank you all
jiw1 is offline   Reply With Quote
Old 01-17-2020, 12:59 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: crab distributor
That's one of the results of the crummy points that many of these folks are pawning-off now-a-days. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-17-2020, 01:22 PM   #3
tubman
tubman's Avatar
It don't look the best, but it will probably run fine. If it does, leave it alone; any replacement points will probably be worse.
Old 01-17-2020, 01:26 PM   #4
marko39
You should bend the stationary part to alighn with the other one. You will not get much life out of them the way they are. Mark
marko39 is offline   Reply With Quote
Old 01-17-2020, 02:38 PM   #5
tubman
tubman's Avatar
I'd leave 'em alone; you stand a good chance of getting them out of alinement trying to bend that out of them. There's probably 90% contact. So they go 18,000 miles instead of 20,000.
Old 01-17-2020, 04:40 PM   #6
marko39
What brand of points are they? It would be good to warn others.
Old 01-17-2020, 05:58 PM   #7
Craig CT
Craig CT's Avatar
Hi jiw1; I think Jim from Third Gen posted about some bad points he found recently. Maybe he'll contribute. Since they're not made correctly they may also be made of inferior materials. Good luck, Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain.
Craig CT is offline   Reply With Quote
Old 01-17-2020, 07:33 PM   #8
35fordtn
35fordtn's Avatar
I wouldn’t bend anything and they appear to be making plenty enough contact.. If you don’t have access to a distributor machine or are not wanting to send it out to be checked, I’d set the points at .015-.016 and see how she runs. It appears to be newer modern points in it. The cotter pin and washers look like those that come with carpenters points. His older points he made weren’t too bad but the ones from the last 7 years or so are terrible, and it’s about the only carpenter made product I can say that about...
Old 01-26-2020, 03:18 PM   #9
jiw1
hi guys,thank you all for all the great info.the fellow i got this from told me when he was building his 46 merc {about ten yrs ago}that he had bought a lot of items from Carpenter.maybe the points came from him.i agree bending the stationary plate looks difficult and could make it worse so i will try it the way it is and see what happens.thanks again,john
Old 01-26-2020, 05:02 PM   #10
FlatheadTed
FlatheadTed's Avatar
Hopfully the points will rag up after a while that will help it start ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 01-26-2020, 08:04 PM   #11
philipswanson
They made a special tool for straightening these out by bending the stationary side. Easily done.
philipswanson is offline   Reply With Quote
Old 01-27-2020, 10:49 AM   #12
jiw1
phil,do you have any information on this tool?it might be nice to have one.thanks
Old 01-27-2020, 11:19 AM   #13
philipswanson
I bought one of these tools off E Bay a while back. They show up from time to time.
Old 01-27-2020, 12:38 PM   #14
jiw1
could you post a picture of it? thanks again
Old 01-27-2020, 01:11 PM   #15
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Ebay is yer friend ............better get it quick.......
https://www.ebay.com/itm/DISTRIBUTOR...EAAOSwJiddk6By
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 01-27-2020, 03:07 PM   #16
jiw1
AGAIN,Bubba comes to the rescue.thank you sir.thank all of you for this great information,johnny
Old 01-27-2020, 03:10 PM   #17
jiw1
i did order it,thanks again
Old 01-27-2020, 03:18 PM   #18
tubman
tubman's Avatar
Let us know how it works.
Old 01-28-2020, 08:48 AM   #19
BUBBAS IGNITION
Ok now , fess up !! Who bought it ????
Was it one of us ?????
[email protected]
Old 01-28-2020, 08:59 AM   #20
JSeery
JSeery's Avatar
Thought jiw1 said he did?
