Old 04-09-2018, 07:38 AM   #1
38 Ford Guy
38 Ford Guy's Avatar
Default 1938 Ford Woody Station Wagon
I am building a 1938 Ford Woody Wagon. Trying to figure out how the antenna assembly on the inside looks. Can someone that has one of these take a picture of the plate that bolts to the header on the inside and send it to me? Thank you in advance.
"If you always do what you have always done then you will always get what you always got."
Henry Ford
38 Ford Guy is offline   Reply With Quote
Old 04-09-2018, 07:51 AM   #2
mrtexas
mrtexas's Avatar
Default Re: 1938 Ford Woody Station Wagon
You mean the attachment to the radio or to the fender? I put the antenna under the running board on my 36 to hide it.
Palindromes:
Do geese see God?
Was it a car or a cat I saw?
Won't Neil call a Walla Walla client now?
Dr. Gong! Get ale to my motel at Egg-nog Rd!
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 04-09-2018, 08:42 AM   #3
rockfla
rockfla's Avatar
I would think the old "Chicken wire" in between top insulation and under the top fabric would be a slick and viable option??? Just like many use in the early sedans!!!!
Old 04-09-2018, 10:32 AM   #4
38 Ford Guy
It is where the knob on the interior header mounts that controls the antenna up and down function.
Henry Ford
Old 04-09-2018, 10:42 AM   #5
deuce_roadster
deuce_roadster's Avatar
I reproduced these a few years ago and no longer have any but I think I have a picture. I will post again after looking through my stuff. It is more complicated then it looks as the back of it has the bevel of the header, both across and at the very top a little of it bevels back and the hole has to be at the right angle to come out in the right spot. I made these out of cast stainless that could be polished so no chroming would be needed.
Update, click on my avatar and look through my 40 woodie picturs and there is one that you can see most of 1/2 of the bracket you seek. I am sure 38-40 would use the same one as that part of the cowl was the same.
Old 04-09-2018, 11:26 AM   #6
woodiewagon46
"Chicken wire" is not an option with a station wagon. The top material attaches over the roof slats, so the 'chicken wire" wood be visible. I think the interior knob, located between the visors twists, to raise the antenna from it's stored position between the exterior two sections of the windshield. If I'm not mistaken it had to be extended by hand. Any '38 owners?
woodiewagon46 is offline   Reply With Quote
Old 04-09-2018, 12:30 PM   #7
rockfla
rockfla's Avatar
Is there NOT an insulation pad or material that goes between the slats and the rubber top?? Just asking?? From my memory on our 37 Station Wagon there is a light tan material between the roof slats.
Old 04-09-2018, 01:15 PM   #8
deuce_roadster
On Nick Alexander's unrestored 40 woodie with original top there was nothing between the slats and the underside of the top material. I looked at and discussed this with him at the Grand National Meet in Tahoe, before I put the top on my car. Not sure about 38 but nothing there for sure in 40.
Old 04-09-2018, 02:13 PM   #9
woodiewagon46
No, the top is simply for the lack of a better description, a rubberized canvas covering that goes over the wood roof slats. There is no padding.
Old 04-09-2018, 03:03 PM   #10
38 Ford Guy
What I am looking for is the antenna mounting on the metal part of the header inside.
Henry Ford
Old 04-09-2018, 06:10 PM   #11
alanwoodieman
attached are some pictures of what I made to do the same thing. fabricated out of SS and tig welded together. not perfect but I did not have any pattern other than the factory holes
Old 04-10-2018, 05:29 PM   #12
woodiewagon46
38, I have searched the V-8 Clubs, magazine data base and looked thru about a dozen or so "Woodie" books that I have. I can't find any pictures of the '38 radio antenna knob, etc. The best I can do is a picture of a '38 with the antenna in the down position, between the two windshields. At this point you are probably going to ether fabricate one as Alan has or keep trying to locate one. Perhaps a trip to the Ford Archives will produce a blueprint. I'll keep looking. If you belong to the V-8 Club and the NWC, perhaps a want add.
Old 04-11-2018, 09:43 AM   #13
philipswanson
Maybe make it like the 40 wagon. The kits are sold by Carpenter & Drake with installation instructions. Should be the same roof line or close.
philipswanson is offline   Reply With Quote
Old 04-11-2018, 01:29 PM   #14
woodiewagon46
The Early Ford Store in San Dimas, CA, also has the kit for the 1940, but it is different than the '38.
Old 04-11-2018, 08:38 PM   #15
38 Ford Guy
Thanks guys. I found a guy that can cast one for me based on photos online.
Henry Ford
Old 04-11-2018, 09:53 PM   #16
swoopNZ
Have a look at page 125 of the 1928-1938 Automotive Hardware and Trimming Supplies.
It is available as a reprint.
1937/38 Windshield header dowel center bracket PN 78 - 711288.
Suits 81A - 760
Could be the one you need.
According to the 1939/40 Body Parts List book, it is used on 1939 convertibles also.
Just to add to the confusion, there is another slightly different one for 1939, PN 91A - 18892, not mentioned in that book.
Regards,
Chris.NZ.
swoopNZ is offline   Reply With Quote
