05-19-2020, 11:41 AM | #1 |
Gas Shutoff Valve, Indented Firewall
I would like to clean and rebuild the gas shut off valve on my Cabriolet. How do you remove the old packing without damaging the valve stem or the valve body? Thank you, Ed
05-19-2020, 12:52 PM | #2 |
Re: Gas Shutoff Valve, Indented Firewall
I just figured it out. Remove the handle and the packing nut. Invert the valve body on top of a vice and with a 1/8 in. diameter pin, gently drive out the valve stem. It will bring the packing with it. Now if I can only make it leak proof with cleaning and new packing. Ed
05-19-2020, 12:57 PM | #3 |
Good luck ! I finally just replaced mine with a new one, and no more leaks !
05-19-2020, 06:39 PM | #4 |
When I did my T/S in 2008, I installed a new, he lasted 10 years. When I did my 31 Roadster P/U I rebuilt one I had, it lasted 1 month. Both cars a indented fire wall.
Buy a new one. |
05-20-2020, 06:52 AM | #5 |
Please send me you old valves, I chucked the stem into a drill, added some lapping compound, when the stem sticks in the body your almost done. Clean off the compound, grease up the stem, reassemble, reinstall.
05-20-2020, 08:56 AM | #6 | |
