Old 05-22-2016, 08:15 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default Beeper for turn signals
I am sure others have had the same problem, that's the reason for this query.
I am using one of the small beepers that has to be wired up using the chromed alligator clips to attach wires to the small beeper which has the small hard formed contacts. Mine does not seem to be making good contact at this point, because if I wiggled the alligator clips around a little the buzzer works fine. Almost too small to solder. A larger beeper, even with tape over it,. is just too loud, ,and the wife says I'm hard of hearing. LOL
Would a little dielectric grease help? Thanks. Lawson
Old 05-22-2016, 09:08 PM   #2
gearhead1952
gearhead1952's Avatar
Default Re: Beeper for turn signals
Could be cheap plating on the alligator clips.
gearhead1952 is offline   Reply With Quote
Old 05-23-2016, 12:22 AM   #3
koates
Ahhhhh come on Lawson, you don't use alligator clips to connect electrical items on a motor car. Use a small electronics soldering iron and resin core solder and solder on a wire to that little terminal after you clean it up to bare metal. You could do that surely. Regards, Kevin.
koates is offline   Reply With Quote
Old 05-23-2016, 01:47 AM   #4
Mart
Mart's Avatar
I use beepers in both my early Fords. I just ordered some el cheapos off ebay. I soldered the wires on no problem and muted them with some tape. Cheap, easy reliable.
Mart.
Old 05-23-2016, 04:10 AM   #5
Lawson Cox
Lawson Cox's Avatar
Yeah, I'll probably do that; and don't call me Shirley. It's just that my hands are so shaky that I have trouble with the delicate stuff.
Old 05-23-2016, 08:45 AM   #6
19Fordy
19Fordy's Avatar
You can also solder the audio speaker wires to the turn signal flasher terminals and it will go beep, beep in synchrony with the turn signal.
Old 05-23-2016, 10:02 AM   #7
Old Henry
Old Henry's Avatar
I picked up a couple of these little buzzers from Radio Shack.
Available here: https://www.radioshack.com/products/...ant=7188471109
They have their own leads for connecting. I put some tape over them to soften them a bit.
"It is good to have an end to journey toward; but it is the journey that matters, in the end. *Ursula K. Le Guin in The Left Hand of Darkness
Old 05-23-2016, 01:08 PM   #8
V12Bill
V12Bill's Avatar
Keep in mind that the buzzers are polarity sensitive.
V12Bill is offline   Reply With Quote
Old 05-23-2016, 01:15 PM   #9
SofaKing
SofaKing's Avatar
This is sidebar question but what purpose does the beeper serve?
The resistance of a loose connection, like alligator clips, tends to increase rapidly making things worse.
SofaKing is offline   Reply With Quote
Old 05-23-2016, 01:25 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
To help forgetful deaf guys with non-self-cancelling turn signals. DD
T5 W/TORQUE TUBE
In that final nano-second while the metal bar speeds toward his furry little head, the oblivious mouse FINALLY realizes WHY the cheese was free!
Old 05-23-2016, 05:27 PM   #11
Barry-ct
Barry-ct's Avatar
I have one... It's called my wife! She tells me when I don't turn mine off!!
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 05-23-2016, 06:22 PM   #12
CarlG
CarlG's Avatar
Available at Snyder's:
http://www.snydersantiqueauto.com/turn-signal-beeper
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-23-2016, 06:27 PM   #13
Blu Dice
Blu Dice's Avatar
I hate mine - too loud and I'm pretty much deaf- lol. So how do I kill this thing without getting too messy - I've got a bad back too.
4 doors are better than no doors!
Blu Dice is offline   Reply With Quote
Old 05-23-2016, 06:28 PM   #14
42guy
42guy's Avatar
I purchased the flasher with a beeper as one unit. Don't remember where other than the internet. Then again I don't recall what I had for supper yesterday.
42guy is offline   Reply With Quote
Old 05-24-2016, 01:44 AM   #15
A bones
A bones's Avatar
It's called finishing the turn. The process begins with telling the world of your intention. After successfully negotiating the corner, and checking the mirrors and surroundings, cancel the signal. The process is not random. It will always be the same.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 05-24-2016, 05:24 AM   #16
SofaKing
SofaKing's Avatar
Got it, thanks.
Thread Tools
Display Modes
