Old 02-07-2021, 04:32 PM   #1
Mike Mayer
Default heads
I have a set of EBA heads What i need to know is it worth having them milled or just leave them alone
Mike Mayer is offline   Reply With Quote
Old 02-07-2021, 06:22 PM   #2
mfirth
Default Re: heads
Hi, See Ol Rons recent post "I'd like to start a new thread..........the man is "The Man".
mfirth is offline   Reply With Quote
Old 02-07-2021, 07:43 PM   #3
38 coupe
38 coupe's Avatar
Default Re: heads
I think milling any head for 0.050 over the pistons is a good idea. While checking for piston to head clearance, also check valve to head clearance.
Old 02-07-2021, 11:18 PM   #4
Newc
Newc's Avatar
Default Re: heads
Well; Any 8ba type head has only a small lip under the thermostat neck and you will be quickly having to mill that portion with the head surface. I always look for excessive milling and shrinkage of the compression 'dome'.. Newc
Old 02-08-2021, 07:03 AM   #5
Ol' Ron
Ol' Ron's Avatar
Default Re: heads
Yes , the 8ba stye head has a clearance problem under the thermostat housing. However the right mill can cut the clearance, But!!! That area is very thin. How do I know?????
Old 02-08-2021, 04:20 PM   #6
Mike Mayer
Default Re: heads
Thank you all I now have a plan
