Old 11-13-2013, 12:46 AM   #1
MrWzrd
Default 28 electric wiper switch
What was used for a switch for the windshield wipers on a 28 Briggs?
I have one wire to ground and two wire dangling where a switch should be but no switch.
MrWzrd is offline   Reply With Quote
Old 11-13-2013, 12:51 AM   #2
Rowdy
Default Re: 28 electric wiper switch
The switch is inside the motor. The control knob opens and closed the switch. Just a basic cam style switch. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 11-13-2013, 12:58 AM   #3
MrWzrd
Ruh Roh Shaggy.... I must not have the right wiper motor.
Mine has no switch. External mount, two wires come inside, one to ground, the other to a non-existent switch.
I guess while I research what should be there I'll just fashion a bracket a put a switch in.
Old 11-13-2013, 09:27 AM   #4
MrWzrd
OK... I'm coming up empty...
Let me start with a simple question.
Is the Original wiper on a 28 Briggs an electric or vacuum?
If electric, which everything seems to point to, is the unit mounted inside our outside the car?
Old 11-13-2013, 09:37 AM   #5
Smurkey
Smurkey's Avatar
Electric, outside.
Per the Judging Standards probably a Owens-Dyneto Corp. OD-C1A or B.
Good diagrams on page 20-3 of the JS.
Steve
PS. I did the same thing on mine. Mounted a tiny switch under the dash as I got a good deal on one without an integral switch but looks correct to the untrained eye...still on the lookout for an original tho...
Smurkey is offline   Reply With Quote
Old 11-13-2013, 09:37 AM   #6
Rowdy
The closed car wiper for 1928 was electric. Most were Owen-Dyneto OD-C1B's. If you look in section 20 of the Judging Standards there is a drawing and a chart to show when each one was used. The 28 wiper motor is alittle hard to find, but they are out there. Rod
Old 11-13-2013, 09:48 AM   #7
Rowdy
Here is a link on a completed listing. This one is the OD-C1A as it has a script. Rod
http://www.ebay.com/itm/Early-1928-F...p2047675.l2557
Old 11-14-2013, 07:18 AM   #8
supergnat
supergnat's Avatar
MrWzrd,
My car has its wiper motor in a bag. The base was broken. I finally called Berts and they had an untested one which I purchased. I am in the priocess of tryint to repair it, The motor works but I neeed some parts. Mine is an OD-C1B for my Oct 2, 1928 Leatherback. Gve Berts a call. Maybe they have another one. Also Model A Wipers sells completely rebuilt units for $395 each. I have been tryung to gat a few parts from them but they have not been respopnsive. Perhaps they will respond if you buy a complete unit.
Good luck,
Supergnat
supergnat is offline   Reply With Quote
Old 11-14-2013, 03:52 PM   #9
BlueSunoco
Rainex works wonders and is a heck of a lot cheaper. The original wiper is only good for looks.
BlueSunoco is offline   Reply With Quote
