08-28-2019, 09:59 PM | #1 |
Exterior Door Handles
How do you identify NOS vs. Repro?
08-29-2019, 06:23 AM | #2 |
Re: Exterior Door Handles
Do these look like original or repro?
08-29-2019, 07:01 AM | #3 |
One issue that I have seen with repro handles is that the chrome plating was applied to the shaft as well as the handle preventing the shaft from fitting in the door latch unless it was dressed down. These were older repros so I don't know if that problem still exists. I am not that familiar with 28-29 handles which I believe your are but originals were nickel plated whereas a lot (most?) of the repros are chrome plated.
08-29-2019, 07:39 AM | #4 | |
08-29-2019, 08:39 AM | #5 |
The handles in your pictures are reproduction.
The orientation of the key slot is different They are cast from some type of pot metal in a mold, originals are made from several pieces of stamped stainless steal or brass and crimped together. Look at the mounting part with the two screw holes, repo is thick cast metal, original is thin stamped metal. Most original shafts will have a key code stamped on them. The 30-31 mounting surface where it touches the door is curved, the 28-29 is straight. You can spot a repro handle from 20 feet away by looking at the key slot. The pictures show original handles. Last edited by 1930 coupe; 08-29-2019 at 08:45 AM. |
08-29-2019, 08:43 AM | #6 |
08-29-2019, 09:22 AM | #7 |
those are some good looking originals
08-29-2019, 09:30 AM | #8 | |
08-29-2019, 01:09 PM | #9 |
