12-04-2017, 12:14 AM | #1 |
To flathead c4 speedway adapter
speedway adapter if any of you use one of these before if so how did you like any comments are appreciated
12-04-2017, 07:16 AM | #2 |
Re: To flathead c4 speedway adapter
Not sure about Speedways..but since you're considering a C4 behind a flathead, I'd recommend Flat-O-Matic out of Oregon.
I used Genes (Flat-O-Matic) quite pleased with it, been in my '40 now for several years.
"Get your facts first..then you can distort them as you please" |
12-04-2017, 09:12 AM | #3 |
I'm installing a Speedway C4 kit behind a 8BA this morning. Only draw back is a little grinding on the block for the starter to clear. Everything bolted together good. I'm putting this in a customers Model A chassis I built. Looks good together. I've done a Flat O Matic kit which also worked good.
12-04-2017, 09:20 AM | #4 |
I have the flat o matic kit and its pretty nice stuff, but havent installed it yet
Speedways stuff is knockoffs of other peoples stuff. Most of its OK but some of its pretty bad |
12-04-2017, 09:35 AM | #5 |
I like the speedway adapter for installing the AoD Trans. The overdrive is very useful.
12-04-2017, 09:55 AM | #6 |
12-04-2017, 11:05 AM | #7 |
Ford has 2 bell housing large and small 6 bolt. I used the small in my 39 ford and if you have trouble finding a c4 you can use one from 6 cylinder like a 80 Granada.
Best thing you can do for a good trans. |
12-04-2017, 11:14 AM | #8 |
I used Speedway’s adaptor for an AOD on an 8ba. Easy install with a little grinding for the starter. No issues or anything bad whatsoever.
12-04-2017, 12:10 PM | #9 |
After doing this install and having the block ground for the stock Ford style starter, I'm thinking why don't they use a Powermaster gear reduction starter which can be clocked for clearance and is smaller?
12-04-2017, 04:04 PM | #10 |
You can use power master with flatomatic they do sell other starters like pm 302 and flathead are different I think
12-04-2017, 04:06 PM | #11 |
I used the Powermaster mini starter on mine and it worked perfect. Also no more Bendix spring.
12-04-2017, 05:49 PM | #12 |
I am very happy with Ford Truck 12 volt starter. No big deal on grinding. Some don’t require grinding.
