02-16-2020, 08:56 PM | #1 |
Oil - again
I have just bought some Havoline 20-W50 oil for my Model A. I bought it because it says "better wear protection for older engines". But then I noticed it also says API SJ. I recall reading somewhere that it should be API SC for Model As? I know some guys think its not important but I want to get it right if possible.
02-16-2020, 10:38 PM | #2 |
Re: Oil - again
Good Evening...Model A Engines should have SN engine oil according to a recent article in Model A Times...Give it a read and then decide...Ernie in Arizona
02-16-2020, 10:47 PM | #3 |
Re: Oil - again
The 20-W50 oil will work just fine in your Model A. This is way better stuff than what was available when your Model A was new.
Chris W. |
02-17-2020, 12:57 AM | #4 | |
Re: Oil - again
SJ is more than good for an A. SC oil will be hard to find and expensive if you do.
02-17-2020, 01:58 PM | #5 |
Re: Oil - again
02-17-2020, 09:14 PM | #6 |
Re: Oil - again
Jim |
02-17-2020, 09:20 PM | #7 |
Re: Oil - again
The cheap oil at Walmart is SN.
02-19-2020, 04:44 PM | #8 |
Re: Oil - again
Rotella T and don't worry about the little stuff.
02-19-2020, 05:53 PM | #9 |
Re: Oil - again
Zinc is not needed after break in on the A motor, zinc was added later due to higher engine speeds requiring stiffer valve springs to prevent valve float.
02-22-2020, 11:17 AM | #10 |
Re: Oil - again
What Rotella do you use? T4?
02-22-2020, 12:01 PM | #11 | |
Re: Oil - again
02-22-2020, 01:50 PM | #12 |
Re: Oil - again
If you do a search, tons of discussion on this. I consider this a good thread.
https://www.fordbarn.com/forum/showthread.php?t=159816 Too much Zinc is bad, more is not better. I use Rotella T4, has some zinc, might help, but should do no harm unless too much zinc is added. I personally do not believe Zinc is required in the Model A motor.. Opinions vary. |
02-22-2020, 04:42 PM | #13 |
Re: Oil - again
Rotella is the little stuff.
