06-04-2016, 05:54 AM | #1 |
Installing a Bendix Drive onto Starter Motor
How do you get the Bendix drive to fit on Motor shaft with the key installed in slot ?
Thx...Mike |
06-04-2016, 07:26 AM | #2 |
Re: Installing a Bendix Drive onto Starter Motor
after you slide the gear assy on the shaft you put the key in, then the end drive piece, the bolt with the pin on the end goes into the round recess on the shaft, use new lock plates, and if the old bolts have been loose and working in the threads replace the bolts too
06-05-2016, 03:14 AM | #3 |
Mike |
