10-31-2013, 06:34 PM | #1 |
Stroker pistons
Just a Query , is it possible or practical to run 4" 1/8 stroker pistons with the shorter 6" 7/8 French rods on a std. 4" merc crank?? Is the gain worth the effort? I know you can run std. 3 3/4 stroke ford pistons on a 4" merc. crank with these rods.
10-31-2013, 06:47 PM | #2 |
Re: Stroker pistons
If I had one, I wouldn't walk across the street to get the other... It will work though. Haven't done it, but all you gotta do is get the piston to the top, don't think there would be a significant advantage to a 1/8" shorter rod.
Karl |
10-31-2013, 06:54 PM | #3 |
Re: Stroker pistons
The French rods and stroker pistons will result in the pistons being about 1/16 inch from coming to the top of the cylinder and you will lose compression and power. Not a good idea in my opinion. Run the stroker pistons with the stock Ford rods and clearance/ machine the heads to about 40-50 thousands and you should gain a little power. To do this the block in the area of the cylinder can not be relieved much.
10-31-2013, 08:52 PM | #4 |
Re: Stroker pistons
The shorter rod is a mystery to me. Rod angularity is important for several reasons, it has an affect on the torque curve and piston acceleration. among other things. Take the SBC they like a longer rod like the 6". The Flathead would do better with a longer rod, unfortunately it is mechanically limited.
In my opinion the short French rod should never be used in any flathead. |
11-01-2013, 03:49 AM | #5 | |
Re: Stroker pistons
Ron is right. Over 4inch stroke the ratio goes bad.....with the 6 7/8 Even 4 1/4 with 7 inch rods the ratio is no good.... I wouldnt run the 4 1/8 with 6 7/8 rods |
11-01-2013, 06:37 AM | #6 |
Re: Stroker pistons
The piston dome to piston pin dimension on 4 1/8" piston is shorter than that on a 4" stroke piston. This will result in a loss of compression if used with 4" crank. Using the 6 7/8" rods and 4 1/8" stroke pistons with the 4" crank will result in a further loss of compression.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 11-01-2013 at 06:42 AM. |
11-01-2013, 07:22 AM | #7 | |
Re: Stroker pistons
Which French rods are we talking about? Are these the ones that Tardell/SF Flathead sells? What is the standard length of a Ford rod-7"? |
11-01-2013, 08:03 AM | #8 |
Re: Stroker pistons
Believe that Tardell/SF Flathead sells 7" standard rods. (no need for anything else)
11-01-2013, 08:41 AM | #9 |
Re: Stroker pistons
11-01-2013, 09:31 AM | #10 | |
Re: Stroker pistons
Perhaps on the 255's with 4" stroke they opted to manufacture new 6 7/8" rods and use the 239" pistons.
11-01-2013, 09:51 AM | #11 |
Re: Stroker pistons
11-01-2013, 02:06 PM | #12 |
Re: Stroker pistons
I'd think it would be more expensive to forge a connecting rod , than relocate the wrist pin 1/8"
11-01-2013, 02:09 PM | #13 |
Re: Stroker pistons
Thanks guys, I thought it was too crazy to work. Just thinking out loud as i was trying to economise and avoid having to purchase a stroker crank. No real loss as it's still a pipe dream. So will have to build the big motor the correct way. How does the extra piston speed and dead time at the ends of the stoke affect things with 4 1/8 stroke?
11-01-2013, 02:37 PM | #14 |
Re: Stroker pistons
Get hold of Smokey Yunick's "Power secrets" book for a long speech on that. He like 2 to one stroke to rod length, and opined that longer rods might likely be better but were outside what could generally be accomplished with available engines.
Ford carefully discussed ofsets and piston travel rates in an engineering text they published in the '30's. |
11-01-2013, 06:27 PM | #15 |
Re: Stroker pistons
I don't know the why's and wherefores, but when the French tooled up for manufacture, they wanted a 239 and a 255. They made the engines common in most ways and did indeed opt to use common pistons between the engines and make up the difference in the longer stroke by using a shorter connecting rod. I suppose one consideration would be that as a military engine, only one range of pistons would need to be stocked, whereas in many cases the rods can be re-used.
The rods use the 8BA shells. I would imagine, also that as this was a military/truck engine (most times governed) the limited rev range would make the rod length ratio a moot point, and they were obviously satisfied with the durability of the engines in service. I have a 4" French motor in my roadster. Mart. |
11-01-2013, 09:43 PM | #16 | |
Re: Stroker pistons
The tax payers are footing the bill so common sense is pretty much an unknown commodity.
11-03-2013, 05:37 AM | #17 |
Re: Stroker pistons
