01-11-2019, 03:34 PM | #1 |
LED Headlights
Logo Lites now sells bright white LED Headlights for Model T, A, and early B Fords. They are as bright as a modern halogen, but pull less current than the 32/50 CP bulb. They focus like the original bulb and fit in the original type socket.
There is a video here: https://youtu.be/FA_9u2kWMNk More info and details here: http://www.logolites.com/products/led-headlights/ -Kyle |
01-11-2019, 03:55 PM | #2 |
Re: LED Headlights
Is this your company? That is a pretty convincing video but I would love to see a picture of the beam pattern against a wall at the distance specified in the service bulletins for focusing headlights. I saw the one picture against the garage door but it's hard to tell that close.
I really don't want to blind oncoming drivers as I hate when it's done to me. Correctly focusable LED headlights are very exciting. Looking forward to hearing more about this. |
01-11-2019, 03:58 PM | #3 |
Re: LED Headlights
Reasonably priced also ! ! !
Paul in CT |
01-11-2019, 04:05 PM | #4 |
Re: LED Headlights
Despite the video and their declarations they do not focus the correct beam pattern.
The off-axis output is extremely evident if a luminary device, in this case the headlamp assembly looks extremely bright from above and to the side, just as shown in their video. If you don't mind blinding oncoming traffic with a D.O.T. illegal beam pattern then buy! |
01-11-2019, 04:18 PM | #5 | |
Re: LED Headlights
The LED emitters were painstakingly designed to be in the exact same location as the two incandescent filament in the original bulb. Moving the LED bulb in and out has the exact same effect as they do on an incandescent since they emit from the same location. I don't have the exact proper setup to do the Ford prescribed focusing, but will see what I can do to show the focused output this weekend. Keep in mind, with a correctly focused factory reflector and an original 21/21 CP bulb, if you could take those bulbs up to a few thousand CP without changing anything else, your eye would see a slightly different pattern. Also, the Logo Lites LED Headlight bulb puts out the same lumens as other DOT approved modern halogens. -Kyle |
01-11-2019, 04:51 PM | #6 |
Re: LED Headlights
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
01-11-2019, 04:57 PM | #7 |
Re: LED Headlights
Lumens comparisons mean nothing if the output goes in the wrong direction.
The holy grail for any aftermarket headlamp is D.O.T. approval of the beam pattern. So far there are many claims but no actual approvals for any aftermarket emitter in a Ford spec parabolic reflector behind a McKee patent spec "Twolite" lens. When that occurs as well as product that has both a realistic color temperature in the 3400-4300K range that matches well with human spectral response at night, combined with a true calculated color rendering index not less than 85 we will have a winner. |
01-11-2019, 05:12 PM | #8 | |
Re: LED Headlights
We first built these with 4300K and, although brighter, they looked just as bad as the original bulbs. Regarding D.O.T. approval, I like what Snyder's says on their website:
Nobody seems to sell the D.O.T. approved, factory specified 21-21 bulbs anymore, and I for one, would not want them. |
01-11-2019, 05:44 PM | #9 |
Re: LED Headlights
How is "high beam" and "low beam" handled with these lights?
The photos online seem to show 8 LED elements on one side, perhaps both sides (hard to tell from the photos). Are they wired such that all 16 LEDs come on for High and only the upper 8 come on for Low? Something needs to dip the beam down when on Low. .
01-11-2019, 05:54 PM | #10 |
Re: LED Headlights
The bottom line for me; I am lot more comfortable driving at night with my LED head lights.
The original bulbs with Brattons new reflectors were still scary out there with all of the bright DOT approved headlights. |
01-11-2019, 06:17 PM | #11 |
Re: LED Headlights
01-11-2019, 06:26 PM | #12 | |
Re: LED Headlights
01-11-2019, 06:27 PM | #13 |
Re: LED Headlights
Just a point of clarity- "D.O.T." approval refers to specific combinations of reflectors/lenses and bulbs, NOT exactly bulbs or LED's themselves. That's why there are so many modern bases that are not interchangeable. As soon as you take ANY bulb/LED that has a specific base and D.O.T. 'approval' then retro-fit it to a reflector/ lens combo that was not originally evaluated by D.O.T. you no longer have an assembly that produces an approved beam pattern, period. Good or bad then becomes an ugly mess of testimonials and pictures that show what someone wants you to see, not what actual D.O.T. specs would report.
On a historical note, D.O.T. did not exist in the Model A era, only a competing and conflicting hundred plus state and local motor vehicle lighting regulations. No 21/21cp, 21/32cp, or 32/50cp BA10 bulb was ever D.O.T. evaluated for performance in an A reflector behind a Twolite lens. I'm all for as much driving beam as I can get but if the off-axis and out of pattern spill blinds other traffic to the point where they can no longer accurately discern my turn signals or (gasp) the edge or center of the road that puts me in extreme danger. |
01-11-2019, 08:49 PM | #14 |
Re: LED Headlights
Phone # for the company???
01-11-2019, 10:05 PM | #15 |
Re: LED Headlights
Here are pictures of original bulbs, at 6 volts, the beam has good cutoff, quite defined edges of the beam, without the lens the round "spotlight " beam, sharp defined edge , not much light outside (scatter) of the beam
When I put in halogen bulbs with curved filament (originally V shape) the edges get a little less defined, still with good cutoff, much brighter, and very little scatter One of my tests for scatter is to stand in line with the edge of the fenders about 4 feet in front, looking at the headlights they look "on", but all you see is a glow of light, not bright to look at, but if you move into the beam you are blinded So that the pictures of led focus are comparable these are at 1 car length--- time to show off your lights |
01-12-2019, 03:56 AM | #16 |
Re: LED Headlights
So what is the expected life span of these? At $30 each I would hope I need not buy them every other year.
-------------------------------------------- Handle by base or aluminum housing only. Touching the LEDs drastically shortens their life span. Normally, the mark on the LED bulb should be up. If high and low beams are backwards, reverse the bulb so the mark is down.
01-12-2019, 04:17 AM | #17 |
Re: LED Headlights
$7.45 for shipping two small bulbs is a little rich.
Hint: You want to sell more...offer free shipping
01-12-2019, 05:48 AM | #18 |
Re: LED Headlights
All modern cars lights blind me if i look straight at them, its because they are brighter. You really dont need to be a mechanical engineer to own a model a. Try them out, if you see better they are good. I will try them and I dont drive at night in my car hardly any.
01-12-2019, 08:11 AM | #19 |
Re: LED Headlights
How about the tail-lites --anything can be found with this Company's product?
Thanks |
01-12-2019, 08:17 AM | #20 | |
Re: LED Headlights
The LED headlight was painstakingly designed to emulate what is available for us to use as a bulb now (except brighter and whiter). So, like the bulb, all 16 emitters are active at the same time, in the same place as the filaments. When you switch from low to high, it goes from reduced output to maximum output to emulate the incandescent bulb. |
