Old 10-09-2019, 09:47 AM   #1
hotrodA
hotrodA's Avatar
Default 32 Cabriolet repro parts?
Hi,
Does anyone reproduce for 32 Cabriolet:
The stainless frames for the door window glass?
The pins on top of the windshield that locate and secure the header?
Door latch mechanisms?
Top kit, now that LB is no more?
Anyone have any of these rare bits?
Thanks for any assistance.
Bill
hotrodA is offline   Reply With Quote
Old 10-09-2019, 07:54 PM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: 32 Cabriolet repro parts?
Heck - all I want is the dang stainless channel that holds the rubber on the A-pillar to window seal. I have one . . . but boy do I need the passenger side! The 32 Cabs are a somewhat rare and unique beast . . . many parts are not common to any other body styles.
Old 10-09-2019, 08:21 PM   #3
Clem Clement
Clem Clement's Avatar
Have you talked to the Cabriolet Society?
Old 10-09-2019, 08:34 PM   #4
Oldbluoval
Oldbluoval's Avatar
Lots of guys may be able to make one by the other. You’d be shocked at how many parts are fabricated on the rarer body styles
Mirror image?? How about post a pic ??
Old 10-09-2019, 10:33 PM   #5
hotrodA
hotrodA's Avatar
Haven't heard of them. Please furnish contact info. Thanks!
Old 10-10-2019, 02:14 AM   #6
Deuce-Addict
I too have a need for a pair of the cabriolet glass guides as does a friend, so if it helped to make it worthwhile for someone to replicate there could be two further sets added to an order.
Am too missing the top garnish molding above the screen and the door garnishes.
Deuce-Addict is offline   Reply With Quote
Old 10-10-2019, 06:55 AM   #7
hop up
hop up's Avatar
I didnt know of a cabriolet society for the 32 just the Model A Ford. It would be cool to have one or even start one.
I love the 1932 cabriolet and have a few plus extras parts ,door posts quarter panels etc.. Since they are hard to find parts and for them as well. We made the window frames and a buddy made the tracks and frames as well off originals. I made the garnish moldings off a set of the originals and really are pretty basic. I have yet to find or even see a window to door glass weather seal. Neither of my cars have them and would love to get or make them to make it weather tight.
Your door latches are 5w and Tudor just a different length rod . I believe I still have some window channels but built a bit different and better then the originals ..
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 10-10-2019, 07:08 AM   #8
Terry,OH
Terry,OH's Avatar
Are the 32 Cabriolet window frames the same as the 33-34? I know the 35 through late 30's are the same but wider than 33-34.
Old 10-10-2019, 07:31 AM   #9
hop up
hop up's Avatar
The 1932 window frames are just 32 size wise but maybe the same construction and similar window channels
Old 10-10-2019, 07:42 AM   #10
Oldbluoval
Oldbluoval's Avatar
Somebody post a picture pls.
Old 10-10-2019, 07:50 AM   #11
hop up
hop up's Avatar
Easier to say then done, my devices will not load pictures on the fordbarn any longer till today crazy..
Old 10-10-2019, 07:56 AM   #12
hop up
hop up's Avatar
32 cab quarter panel chunk
File Type: jpg 9D8FCCFE-8CE6-4B8B-BE9D-1F5040E3FAD3.jpg (52.6 KB, 52 views)
Old 10-10-2019, 07:57 AM   #13
hotrodA
hotrodA's Avatar
Here are pics of the window trim and rubber from the late Dick Spadaro.
Old 10-10-2019, 08:05 AM   #14
hop up
hop up's Avatar
Original frame trimmed at the sliders for some reason under the reproduction stainless frame on top
Old 10-10-2019, 08:59 AM   #15
TJ
TJ's Avatar
The rubber window seal looks the same as the later Ford convertibles (35-48). If they are the same then you can use the channel that is used on the later convertibles. You probably will have to shorten the channel. Had a '32 cabriolet years ago and I recall the channel and rubber came from repo stuff for the later convertibles.
Old 10-10-2019, 09:24 AM   #16
hop up
hop up's Avatar
Thank you TJ for the info and will order a set today.
Old 10-10-2019, 06:07 PM   #17
DavidG
DavidG's Avatar
Except for very early '32 cabriolets, the stainless channel and rubber on the A pillars is the same as later cabriolets and convertibles as TJ indicates. While I haven't checked lately, both Bob Drake and Dennis Carpenter offered excellent reproductions of both and also offered a fuzzy tape to cover the rubber to duplicate the original surface on the rubber. (Very early cabriolets used a narrower channel and rubber insert; it's all in the book.)
Old 10-30-2019, 07:35 AM   #18
hop up
hop up's Avatar
Thank you for the info on the rubber weather stripping, I just cant seem to find that info in your great book.
Old 10-30-2019, 10:45 AM   #19
DavidG
DavidG's Avatar
Please see page 16-7.
Old 10-30-2019, 10:51 AM   #20
Bored&Stroked
I lent my DavidG books to a friend . . . and of course he hasn't brought them back. Does anybody happen to know the width of the two different rubber seal channels for the A-pillars on a 32 Cab? I'd like to determine whether I need an early or late version. Thanks gang!
