Old 01-22-2013, 12:01 PM   #1
kwisor
kwisor's Avatar
Default Steering column question
hello
i have the steering column out of the car and went to draun the fluid to change it before i reintalled it and found it full of grease how do i clean it out to put the 600 waight oil back in before i rein stall it 1930 tudor
kevin
1930 model a tudor
1923 model t roadster
kwisor is offline   Reply With Quote
Old 01-22-2013, 12:44 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Steering column question
I would just add the heavy gear oil and not worry about the grease. The gear oil will fill the voids and also mix with the grease.
Old 01-22-2013, 01:27 PM   #3
kwisor
kwisor's Avatar
thanks tom
kevin
