Old 05-24-2018, 02:58 AM   #1
Rob Needs
Rob Needs's Avatar
Default Cylinder heads.
I have a chance to buy a head that came off a 28 will this go straight on my 31?
Rob Needs is offline   Reply With Quote
Old 05-24-2018, 03:24 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Cylinder heads.
Yes, if both are the same block configuration (-both US exports). For grins & giggles, you may want to post a picture of it in case it is the early 1928 version which is more valuable over the other more common versions.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-24-2018, 10:47 PM   #3
daveymc29
daveymc29's Avatar
Not to highjack the thread, but what does the 28 look like that is different? I'm on this site right now to find information on a head that has "Ford USA" on it. Haven't noticed one of those before. Any comments welcome.
daveymc29 is offline   Reply With Quote
Old 05-25-2018, 06:05 AM   #4
BRENT in 10-uh-C
The biggest give-away is the extended boss for the distributor hold-down screw & locknut. Look at the head below and see how the casting boss protrudes away from the head casting..
BRENT in 10-uh-C
Old 05-25-2018, 08:16 AM   #5
juke joint johnny
juke joint johnny's Avatar
As you are in the UK Further to what Brent said:
Some of the engines found here in the UK are the European 3" bore engine ,
That head will fit and raise the compression , But there are some steam holes that need to be blocked off before you can use it on the 3 7/8" bore USA engine
John Cochran
juke joint johnny is offline   Reply With Quote
Old 05-25-2018, 02:59 PM   #6
Rob Needs
Rob Needs's Avatar
Here is the head.
