Old 08-21-2020, 02:30 PM   #1
roundbill
Send a message via MSN to roundbill
Question 1936 ford tudor cab mount photo
Hey out there, need a little help. Need a picture of the cab to chassie mount on a 36 ford tudor. just behind the doors, both mounts are rotted away. Need to fab them cant buy them. Any help will be appreciated. Thanks. Roundbill
roundbill is offline   Reply With Quote
Old 08-21-2020, 02:35 PM   #2
JSeery
JSeery's Avatar
Default Re: 1936 ford tudor cab mount photo
Have you tried the Wescott site?
http://www.wescottsauto.com/
http://www.wescottsauto.com/WebCatal...09-F-Frame.pdf
Old 08-22-2020, 04:18 PM   #3
TJ
TJ's Avatar
If you are talking about those rectangular outriggers on the side of the frame you use to be able to get them from Chassis Engineering. You might also try TCI in California
Old 08-22-2020, 04:25 PM   #4
Krylon32
I see that Pete & Jake's has taken the manufacturing of the Chassis Engineering body mounts. I always used them when I was still building 35-40 customer chassis, had no problems with them.
Krylon32 is offline   Reply With Quote
