01-15-2018, 02:33 PM | #1 |
Ignition Switch
My car currently just has a toggle switch in place of the key. I purchased the on/off plate, switch plate ring and the re-pop switch and cable. What else do I need to convert this? I have the Les Andrews book, but left out at work over the long weekend.
Thanks! Sent from my SM-N920V using Tapatalk
1931 Model A Victoria 1950 Mercury 8 Member: MAFCA, MARC, Northern Ohio Model A Club www.northernohiomodela.com |
01-15-2018, 04:46 PM | #2 |
Re: Ignition Switch
You said you have a pop-out switch and cable to install. Before installing it you should check out the ignition wiring against the original wiring diagram before you doing it.
AL in NY |
01-15-2018, 04:48 PM | #3 |
Re: Ignition Switch
which repop switch did you get? if you got the $13 or so one with the 2 screw terminals sticking straight off the back id return it and get the fake poppot nurex one thats like $35...
1929 Model AA - Need long splash aprons! |
01-15-2018, 04:55 PM | #4 | |
Re: Ignition Switch
01-15-2018, 05:03 PM | #5 |
Re: Ignition Switch
This is what I got, along with the on/off plate and the ring to hold that in place.
01-15-2018, 06:38 PM | #6 |
Re: Ignition Switch
its still a basic on off switch so dont let that confuse you. Id check your wiring from the diagram shown above as these cars can and have been wired any number of ways...
