07-16-2018, 09:36 AM | #21 |
Re: Turn signals but keeping single element bulb
The Fords I drove in my youth ('56 & a '57 models) had clear front turn signal bulbs and clear lenses in them as original equipment and seemed to do the job. It was somewhere in the sixties model years the the cars changed over to amber bulbs if memory serves me correctly. I have turn signals on my '32 and I use clear bulbs on the front of it because it's old and so am I!
07-16-2018, 10:25 AM | #22 |
No matter what you do; you have to rewire both front and rear circuits to provide separate left and right wires; should be no big deal to add new double contact sockets to the front at the same time.
If you are resistant to that you can always use relays as Andy mentioned; relays also have the advantage of providing the ability to use a simple toggle switch or a vintage four wire signal switch. The trailer converter mentioned could also let you use the single element front bulbs for dual purpose; but seems like an overly complicated idea. |
07-16-2018, 12:09 PM | #23 |
My 61 Ford V8 came with white front turn signal bulbs, but in 62 I bought amber colored bulbs at the auto supply store.
Bruce
Works good Lasts long time |
07-16-2018, 12:16 PM | #24 |
It's just my humble opinion, but you can't use a side light as an indicator. I'm talking white at the front here, like the OP asked. Side lights are 5W. Indicator bulbs are 21W. Using a 5w bulb as in indicator just isn't bright enough.
The method I described works great and is really simple. Using relays or fancy switches is the best solution at the back where you have 21W brake light bulbs, but are not the answer for the front. Mart. |
07-22-2018, 06:40 PM | #25 |
https://cgfordparts.com/CATPICS/LOGO...0035000400.JPG is the complete socket with wires. Thinking of putting this in the front parking light socket.
The one Meric referenced in post 4 is only the end with wires not the socket too. https://www.vintageautogarage.com/He...7r-90651-k.htm What do you think of this switch? I have led tail lights now should I use the led relay? will it handle bulbs up front or should I convert the front to led 2 brightness bulbs? here is a two stage led bulb i found. https://www.superbrightleds.com/more...15d-bulb/2625/ Any thoughts on the switch, socket exchange and LED bulbs up front? I already have the LED tail lights installed. I know I'll have to run wires everywhere and thats okay. |
07-22-2018, 10:02 PM | #26 | |
They are there so that when you engage reverse on the freeway at 50mph the cars following can dodge the fragments of your exploding gearbox !
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
07-23-2018, 12:22 AM | #27 |
07-23-2018, 10:29 AM | #28 |
Originally Posted by Karl
They are there so that when you engage reverse on the freeway at 50mph the cars following can dodge the fragments of your exploding gearbox ! I saw a green 1956 ford hit reverse at a drag strip. Car slowed down and started backing up. Heard his axle broke the next week. Bruce
07-24-2018, 11:41 AM | #29 | |
What are you doing for the rear directionals? |
07-24-2018, 01:48 PM | #30 |
My high school buddy had a 49 buick convt. He would put it in R while going forward just to thrill the girls. Doing that saved our bacon one night when a 48 Chrysler town & country vert pulled out from a side street in front of us. He evidentially did have to repair the dynaflo tranny.
07-24-2018, 04:01 PM | #31 | |
I have ordered a turn switch and relay and led lights for front. I will replace the single element sockets up front with double element socket and Amber bulbs. LEDs on back already. I'll run the wires needed. |
07-24-2018, 05:00 PM | #32 |
A question on your rear LEDs... is the light worth it?.. I mean do I need that bright a light to the rear?
WALT "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm". "Old enough for the experience & too young to know better" |
07-24-2018, 05:26 PM | #33 | |
My wife followed me a couple times and fussed at me abut how dim they were. I thot she was just exaggerating. When the neighbor actually turned arund to tell me that I figured I would go LED on the rear |
07-24-2018, 09:07 PM | #34 | |
FWIW: I went with http://www.turnswitch.com/Turnsignal.htm. Very pleased. |
07-25-2018, 12:18 AM | #35 | |
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
07-25-2018, 12:52 AM | #36 |
The Signal Stat should not matter, it is just a switch. But the flasher does come into play esp when you mix and match bulb types. Ok that is all I can add. I run stock type bulbs on my 48 and T with Signal Stat switches.
07-25-2018, 01:56 AM | #37 |
I'v heard that - how big is big? does this affect LED's?
07-25-2018, 02:24 AM | #38 | |
Full range of USA made flashers Novita technologies which bought out Tridon http://novitatech.com/?q=aftermarket/products Anyone using a standard 6v positive system should use a LL535 . Rock Auto does them at a good price. There will be some here that would suit LED. GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" Last edited by Graeme / New Zealand; 07-26-2018 at 03:19 PM. |
07-25-2018, 05:07 PM | #39 |
Ed
You could accomplish what you want with a diode on each light |
07-25-2018, 08:03 PM | #40 |
