Old 10-11-2016, 12:00 AM   #1
700rpm
700rpm's Avatar
Default Update on my new Stipe shocks
When I first put them on I commented here that they were nicely made but I didn't notice much difference from my old Hoodeyes. But today I went to the Service Bulletins to see how to adjust them for cold weather driving. After making that adjustment, I realized I didn't have them properly adjusted before. And now, Wow! What a difference! They are great! I had assumed they came adjusted from Stipe, but that was not the case.
When all else fails, read the instructions!
Ray Horton, Portland, OR
Old 10-11-2016, 12:52 AM   #2
updraught
updraught's Avatar
Default Re: Update on my new Stipe shocks
When you adjusted them did they adjust harder in both directions or only rebound ie. lever going down?
A bit hard to justify the expense with the exchange rate at the moment.
updraught is offline   Reply With Quote
Old 10-11-2016, 10:37 AM   #3
700rpm
700rpm's Avatar
I only moved the adjustment needle as specified in the Service Bulletins. I didn't test the resistance by hand.
Old 10-11-2016, 10:37 AM   #4
700rpm
700rpm's Avatar
I only moved the adjustment needle as specified in the Service Bulletins. I didn't test the resistance by hand. Ford had a special KRW setup for that.
Old 10-11-2016, 11:09 AM   #5
C26Pinelake
mine came with instructions, I am surprised yours did not ! Wayne
C26Pinelake is offline   Reply With Quote
Old 10-11-2016, 11:27 AM   #6
harleytoprock
When I was playing with the adjustment on my Stipe shocks, adjusting only seemed to effect the rebound.
harleytoprock is offline   Reply With Quote
Old 10-11-2016, 03:48 PM   #7
updraught
updraught's Avatar
OK. Thanks.
I read a bit of an extract from a book on the web the other day that said Henry insisted on the most expensive shocks available at the time and they cost a dollar each, if I remember right.
Old 10-11-2016, 04:17 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
OK. Thanks.
They have gone up a mite...
Old 10-11-2016, 06:22 PM   #9
updraught
updraught's Avatar
This is the book.
Interesting about the fuel tank, brakes and shocks.
Can't seem to find the bit about the cost shocks tho ... might be there somewhere.
https://babel.hathitrust.org/cgi/pt?...iew=1up;seq=37
might take a while for the page to load.
