06-21-2020, 10:37 AM | #1 |
1935 Ford Temp Gauge
I want to run a 2nd temp gauge.
Did the 35 only have a provision for a temp probe in the drivers side water pump? Are the pumps interchangeable where I could run a drivers side pump on the passenger head?
Tim Downtown, Ca |
06-21-2020, 11:51 AM | #2 |
Re: 1935 Ford Temp Gauge
replacement pumps had a plug so they could be used on either side
06-22-2020, 06:28 AM | #3 |
I am not aware of a RH, OEM or aftermarket pump with the temperature probe fitting. The LH pump can be used on the right but the fitting winds up under the generator, I am not sure if the temperature probe can be installed in this location.
06-22-2020, 07:27 AM | #4 |
