03-01-2020, 12:15 PM | #21 |
Re: flathead fuel pump push rod
Good. Not sure how you solved the problem. Did you grind down another rod and use it as a lever to move the bearing OR did you grind down another rod to a smaller dia. so it would fit the offset bearing hole?
