06-24-2019, 01:38 AM | #1 |
6v Coil Wiring
59A Engine setting up on a Run Stand. Stand is timber construction.
6v +ve earth. Using a round type coil. Wire from ignition goes to -ve side of coil and +venside of coil to distributor? Just seeking confirmation. Also since timber is used for stand frame to bolt a metal strap to timber frame and connect earths to this point? Appreciate advice. Phil NZ |
06-24-2019, 01:57 AM | #2 |
Re: 6v Coil Wiring
Correct
06-24-2019, 08:45 AM | #3 |
Re: 6v Coil Wiring
