Old 01-17-2019, 07:10 PM   #1
Eagle43
Default Thread Locker
I'm working on my 1951 8BA flathead. Do I need to use thread locker on the connecting rod nuts etc. What are people doing?
So far I have the valves out, lapped and reinstalled with two stubborn ones replaced. I then checked compression and found none for some cylinders and up to 40 for others. I'm in the process of taking out the pistons. Looks like lots of rings are stuck. The bores are still standard and the bearings are .010 under. I plan the replace the rings and bearings which are showing some copper in a few places. I'm new at this and any advice would be appreciated.
Eagle43 is offline   Reply With Quote
Old 01-17-2019, 07:18 PM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Thread Locker
No. Just use tork specs. http://vanpeltsales.com/FH_web/flath...ecs49-53V8.htm
Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 01-17-2019, 07:33 PM   #3
rotorwrench
rotorwrench's Avatar
Some had pal nuts but not all.
Old 01-17-2019, 08:12 PM   #4
J Franklin
J Franklin's Avatar
I use locktite blue on every fastener as insurance, and it retards rust from locking up nuts. They stay together and come apart easily.
Old 01-17-2019, 08:15 PM   #5
russcc
For connecting rod nuts, I bought NOS ones from Fred Wilner at So Side Obsolete as they are 1 time use.
russcc is offline   Reply With Quote
Old 01-17-2019, 08:59 PM   #6
Ronnie
Ronnie's Avatar
Just use small block Chevy rod nuts you can get them at a bus stop and no loctite.
R
Ronnie is offline   Reply With Quote
Old 01-17-2019, 10:04 PM   #7
Pete
Pete's Avatar
R
Those are called Marsden nuts. Available at many places. Reusable also.
Used in many modern OEM engines.
Old 01-18-2019, 12:11 AM   #8
Marvin/TN
Send a message via AIM to Marvin/TN
I like you animation Jack, reminds me of my days in the USAF back in the 60's. I was trained as Jet over two engines but worked on many more piston engined aircraft than I did Jets. I didn't really understand how a radial engine worked until after I got out of the USAF. I worked on a lot of P&W R-4360'S with 28 cyl's and 2800's and 3350's and to this day I love the sound of a Radial engine.
Marvin/TN is offline   Reply With Quote
Old 01-18-2019, 11:21 AM   #9
philipswanson
99% of parts people never heard of these. Order the SBC nuts.
philipswanson is offline   Reply With Quote
Thread Tools
Display Modes
