Old 10-06-2018, 02:59 PM   #1
38fordragtop
38fordragtop's Avatar
Default 38' Hood/Fender Aprons Mounting Help?
81A-16750-RK Fender Apron/Hood Mount Kit
Can someone give me a clue on where this hardware mounts. When I bought my 38' Deluxe thefenders and hood were not on the car. Icould guess where some of this might go but could be way off.
Each apron has 3 indentions and 2 notches per panel andboth have an 'L" shaped brackets at the front of each and nut at the rear andI have no idea where or what these mount to. Additionally on each side of the cowl there are three large holes thatare cover by these panels, what are these for?
Thanks to any and all for your help
38fordragtop is offline   Reply With Quote
Old 10-06-2018, 03:14 PM   #2
swoopNZ
Default Re: 38' Hood/Fender Aprons Mounting Help?
Mounts the inner to outer front fenders.
Drake's catalog online should have an illustration.
swoopNZ is offline   Reply With Quote
Old 10-06-2018, 03:14 PM   #3
swoopNZ
Drakes online catalogue should have an illustration.
Old 10-06-2018, 04:11 PM   #4
40cpe
40cpe's Avatar
The "L" shaped bracket near the front are to bolt to matching tabs on the radiator. The three large holes in the cowl are for rubber bumpers. The notches in the hood sides are for the threaded bolts and wingnuts that screw into the fender at matching locations.
40cpe is online now   Reply With Quote
Old 10-06-2018, 05:05 PM   #5
melisahe
melisahe's Avatar
learn something new every day! I didn't know that the large holes had rubber bumpers that fit them!
melisahe is offline   Reply With Quote
Old 10-06-2018, 05:44 PM   #6
fordv8j
fordv8j's Avatar
The L shaped bracket bolts to a flat piece of metal about 3'' long that bolts to side of radiator with 2 little bolts with square sholders on them, like a small stove bolt...then there is an L shaped bracket that bolts to hood hinge, with 1/4'' threads in it,...the hole near the top of side panel is for a 1/4'' slot head screw,that screws into that bracket
fordv8j is offline   Reply With Quote
Old 10-10-2018, 08:00 AM   #7
38fordragtop
Thank you much I'll look into that.
Old 10-10-2018, 08:00 AM   #8
38fordragtop
Thanks for the help just hate being lost.
Old 10-10-2018, 08:01 AM   #9
38fordragtop
Always see your post, figured if anyone knew about this you would. THANKS
Old 10-10-2018, 08:02 AM   #10
38fordragtop
And now we both know, thanks.
Thread Tools
Display Modes
