Old 08-25-2013, 05:20 AM   #1
1 Raggedy Ride
Default 1935 Ford spare tire cover info needed
Could someone please tell me if there was more than one tire/tread band for the 1935 ford spare tire cover........what are the widths of any bands related to tire sizes 6.00-16 & 6.50-16?????....Any & All help appreciated......
1 RAGGEDY RIDE
1 Raggedy Ride is offline   Reply With Quote
Old 08-25-2013, 10:59 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 1935 Ford spare tire cover info needed
As far as I know only 1 band was used.Weather or not it will work on a 6.50 not sure.
deuce lover is offline   Reply With Quote
Old 08-25-2013, 12:46 PM   #3
Mike in AZ
Mike in AZ's Avatar
according to the book....2 sizes, one for 6.00 and one for 6.50...all it says...Mike
Mike in AZ is offline   Reply With Quote
Old 08-25-2013, 04:28 PM   #4
1 Raggedy Ride
Mike, Thanks for the help......what book are you referring to, since I don't have any books yet, for 1935????
1 RAGGEDY RIDE
Old 08-25-2013, 05:08 PM   #5
malpais
malpais's Avatar
Does a 35 look like this? Fella gave me this when I bought a 39 tranny (no good I'm afraid) from him.
Gordon
Don't mind learning from my mistakes. Just wish I didn't learn EVERYTHING from my mistakes..
malpais is offline   Reply With Quote
Old 08-25-2013, 05:30 PM   #6
41PICUP
41PICUP's Avatar
That one is for a 36
41PICUP is offline   Reply With Quote
Old 08-25-2013, 08:25 PM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
I believe the book Mike is referring to is the 1935-36 Ford Book puplished by the Early Ford V-8 Club of America. You can go to their website and order the book on line. Definitely a must have book if you are working on a 35 or 36 Ford passenger car.
John
Old 08-25-2013, 08:29 PM   #8
Mike in AZ
Mike in AZ's Avatar
yep, that's the one, John....thanks....Mike
Old 08-25-2013, 08:31 PM   #9
Shadetree
Shadetree's Avatar
My spare tire cover won't fit on a 600-16 and I have two of them. I think the raised ridge around the white wall is the problem.
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 08-25-2013, 09:18 PM   #10
Elmo Rodge
Elmo Rodge's Avatar
Mine measures 5 11/16". Wayno
Life is not a spectator sport.
Elmo Rodge is offline   Reply With Quote
Old 08-26-2013, 03:16 AM   #11
danliveshere
danliveshere's Avatar
Mine fit on a 600-16 but not 650-16. That is the tire cover will fit the 650-16 but you can't put the face plate in as well. It would be a lot of work to weld a wider lip on all the way around, but I would like to use the 650-16 tyres
danliveshere is online now   Reply With Quote
Old 08-26-2013, 04:37 AM   #12
35ragtop
35ragtop's Avatar
Well I cheated , I run 6.50 WW on the car and the spare tire is a 600 B W.
Fits well and you cant tell. - at least its a real spare tire .
35ragtop is offline   Reply With Quote
Old 08-26-2013, 05:41 AM   #13
1 Raggedy Ride
Thanks to all who replied......unless I can find the wider band, '35 ragtops method might workout to be the best choice for me.............
1 RAGGEDY RIDE
Old 08-26-2013, 06:32 AM   #14
jfcrash
jfcrash's Avatar
I recently had the problem were the band for my ’35 spare tire a 600-16, would not slip over the tire enough to hold the cover in place. Even without the cover in place, I could not force the band to sit any lower on the tire.
I don’t know what the “Book” width should be for a 1935 600-16….but the band that did not fit had a width of 6 ¼” and the band that does fit and comes over the cover and holds it in place has a width of 6 5/8”.
To be honest, I don’t know if either is correct for ‘35
Hope this helps, Jim
______________________________________________
jfc
I couldn't repair the brakes, so I adjusted the horn louder....
jfcrash is online now   Reply With Quote
Old 08-26-2013, 02:38 PM   #15
barnfind
Let some air out and carry a pump?
barnfind is offline   Reply With Quote
Old 08-26-2013, 03:54 PM   #16
David J
David J's Avatar
The 5 1/4" one is 33-34 . Does it have a stainless band around it's outer center bead ? If yes it's 33 and if it is just the raised bead it's 34 .
David J is offline   Reply With Quote
Old 08-26-2013, 07:14 PM   #17
Don Rogers
Don Rogers's Avatar
Here is the correct profile for 35 spare tire cover ring. It was designed for a 6:00 x 16 bias ply tire.
Don Rogers
Don Rogers is offline   Reply With Quote
Old 08-26-2013, 08:40 PM   #18
Barn Junk
Barn Junk's Avatar
Don Rogers
That's not much help. It has the width from about 5 1/8 to 5 3/4 inches. Now I'm even more confused!!
I did go measure an original 36 ring and it is exactly 5 3/4 inches wide.
Barn Junk is offline   Reply With Quote
Old 08-26-2013, 09:10 PM   #19
Don Rogers
Don Rogers's Avatar
Barn Junk, The drawing is a Ford Motor Company drawing from 1935 and it reflects the allowable tolerences for the band when it is in the extended and contracted position. I'm sorry that it isn't much help to you.
Old 08-27-2013, 05:57 AM   #20
chuck stevens
chuck stevens's Avatar
They fit these 5.00x16s just right.
chuck stevens is online now   Reply With Quote
Thread Tools
Display Modes
