Old 06-24-2019, 01:38 AM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 6v Coil Wiring
59A Engine setting up on a Run Stand. Stand is timber construction.
6v +ve earth. Using a round type coil. Wire from ignition goes to -ve side of coil and +venside of coil to distributor?
Just seeking confirmation.
Also since timber is used for stand frame to bolt a metal strap to timber frame and connect earths to this point?
Appreciate advice.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 06-24-2019, 01:57 AM   #2
Brian
Brian's Avatar
Default Re: 6v Coil Wiring
Correct
Old 06-24-2019, 08:45 AM   #3
JSeery
JSeery's Avatar
Sounds good.
JSeery is online now   Reply With Quote
