Old 06-17-2019, 09:37 AM   #21
38bill
38bill's Avatar
Default Re: sleeved wheel cylinders
Speedway lists them as: " All new castings with corrosion resistant SS sleeves.....".
38bill is offline   Reply With Quote
Old 06-17-2019, 10:01 AM   #22
flatrod
[QUOTE=Frank Miller;1768423 If it was a loose fit then you certainly would have fluid leaking behind the sleeve. I thought of machining a groove with a lock ring to prevent this but a properly pressed in sleeve should not have this problem. At least I would not think it would.[/QUOTE]
Both sides showed signs of leakage on the small side of the wheel cyl. Its the large side that blew out on the left side of the car. I too thought about adding some kind of locking ring, but think best to just go with cyl that are not sleeved.
flatrod is offline   Reply With Quote
Old 06-17-2019, 11:29 AM   #23
john in illinois
john in illinois's Avatar
Barnfind08 on this forum has NOS cylinders.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 06-17-2019, 12:50 PM   #24
Tony, NY
If you want to try and save them, there are retaining compounds made by Loctite that work on interference and slip fits.
https://www.henkel-adhesives.com/us/...compounds.html
Tony, NY is online now   Reply With Quote
