Old 10-19-2019, 08:46 PM   #1
freddie@healthcoga.co
Default "Saging' Frame? /Motor Mounts?
Speedometer cable and connecting collar in contact with Brake bar - Brake Bar supports to frame have multiple spacer shims on all four contacts - Motor Mounts are original metal/ not rubber. Doors - Hood - Cowl all in line. New to A'ing as an owner/driver. Not a tinkerer - Thanks for thoughts of Cause - Solution(s)/with positives and negatives. Or just continue driving and enjoying. Thanks again!! D
freddie@healthcoga.co is offline   Reply With Quote
Old 10-20-2019, 07:43 AM   #2
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Default Re: "Saging' Frame? /Motor Mounts?
This can result from cracked rear engine mounts. If that’s not it, maybe the frame is bent. There are shops that can fix the frame.
Jacksonlll is offline   Reply With Quote
Old 10-20-2019, 08:21 AM   #3
Oldbluoval
Oldbluoval's Avatar
Frame sag is a common phenomenon but very hard to correct with body on the frame.
Oldbluoval is offline   Reply With Quote
Old 10-20-2019, 10:41 AM   #4
Russ/40
Russ/40's Avatar
Get that frame FLAT, and everything fits together sooo much better.
Russ/40 is offline   Reply With Quote
Old 10-20-2019, 05:20 PM   #5
burner31
burner31's Avatar
Does your GAV spring back nicely when you pull it, or does it stick a little?
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Thread Tools
Display Modes
