Old 04-07-2021, 06:05 AM   #1
36coupe
36coupe's Avatar
Default How to repair damage to a deck
How can a flathead block deck be repaired? I have a gouge from a valve seat to the coolant port on the sealing area to repair about a 1/4 wide and a 1/32-1/16” deep.
JB weld would be too easy, I don’t think it would hold.
Can it be bronzed? A couple dabs with the mig and filed down? Would silver solder be too hot? I’ve repaired an exhaust manifold with a nickel rod on the arc welder but it was much thicker and I would be way to nervous to strike out an arc on the block.
Thanks
36coupe is offline   Reply With Quote
Old 04-07-2021, 06:25 AM   #2
JWL
Default Re: How to repair damage to a deck
I would like to see a picture.
JWL is offline   Reply With Quote
Old 04-07-2021, 07:36 AM   #3
36coupe
36coupe's Avatar
Not one of my better days. Fighting stuck valves.
Old 04-07-2021, 07:41 AM   #4
36coupe
36coupe's Avatar
Damage
File Type: jpg 7B01D733-7370-4B27-99F3-D69A2380EC96.jpg (36.7 KB, 232 views)
File Type: jpg 265B4A5E-874C-42A3-800A-6125A6F4330B.jpg (36.2 KB, 197 views)
Old 04-07-2021, 07:47 AM   #5
fordwife
JB Weld is supposed to be good for up tp 400 degrees F. However if the damage goes into the seat I would put a new insert in that seat. But I would reserve judgement until I could see a photo.
fordwife is offline   Reply With Quote
Old 04-07-2021, 07:51 AM   #6
fordwife
Now that i've seen the photos. I would not be afraid to use JB weld, provided there is not a crack that goes deeper than the pictures show.
Old 04-07-2021, 08:58 AM   #7
Jack E/NJ
Jack E/NJ's Avatar
Agreed JBWeld should work fine. A bit more substantial fix might be to paint the gouge with a tinplating solution. Then drip soft solder to fill the void. Jack E/NJ
Old 04-07-2021, 08:59 AM   #8
36coupe
36coupe's Avatar
No crack, self inflicted.
Old 04-07-2021, 09:04 AM   #9
36coupe
36coupe's Avatar
Okay. I have a few different solders that melt at different temperatures from repairs to Indian gas tanks
I like the idea of solder
Old 04-07-2021, 12:47 PM   #10
19Fordy
19Fordy's Avatar
I agree with Kay. My old eyes can't discern those unclear photos. Did you use the MACRO setting on your camera for clarity?
Old 04-07-2021, 02:31 PM   #11
36coupe
36coupe's Avatar
More pictures
File Type: jpg A59E540B-F0D9-499B-9369-54C8A91C181F.jpg (32.9 KB, 612 views)
File Type: jpeg 2CCCBEC7-9593-4A6C-B527-01A764787A66.jpeg (77.5 KB, 614 views)
Old 04-07-2021, 02:33 PM   #12
Will D
Will D's Avatar
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 04-07-2021, 02:40 PM   #13
51 MERC-CT
51 MERC-CT's Avatar
You have to determine if the crack goes all the way down into the valve chamber before any method of repair can be done ( if possible)
Otherwise you are SOL.
Old 04-07-2021, 03:35 PM   #14
36coupe
36coupe's Avatar
It is not a crack, it’s a gouge caused by me.
Old 04-07-2021, 04:08 PM   #15
Tim Ayers
What caused that deep of a gouge? Chisel?
Old 04-07-2021, 06:07 PM   #16
Doublepumper
Doublepumper's Avatar
I'm thinking epoxy won't take the heat in that area and will eventually fail. Silver solder doesn't work well for a filler. Brazing with bronze rod may be the best method to fill it without imparting too much heat and distortion. That's a tough spot, due to the uneven thickness and hole edge. Good preheat and slow cool will be the most important things for success.
Good luck!
Ever stop to think and forget to start again?
Doublepumper is offline   Reply With Quote
Old 04-07-2021, 09:02 PM   #17
36coupe
36coupe's Avatar
Good luck!
Okay thanks
Old 04-07-2021, 09:03 PM   #18
36coupe
36coupe's Avatar
Recep saw
Old 04-07-2021, 09:27 PM   #19
53Customline
53Customline's Avatar
Solder or brazing likely better than JB weld. Although that is some tough stuff properly installed. Patched a lowerUnit on outboard Motor that lasted years in tough saltwater conditions.
53Customline is offline   Reply With Quote
Old 04-07-2021, 09:31 PM   #20
Russ/40
Russ/40's Avatar
I would stitch it, from the water hole, to just inside the fire ring.
