01-04-2014, 11:22 PM | #1 |
Early '46 Generator Rebuild
Hello,
I am taking on rebuilding the generator of my '46 V8 Ford. According to Henry's "Repair Manual - Generating and Starting Systems 1933-1947" my generator has the pulley screwed to the armature. The armature tested to be OK, so hacking into it to save the pulley and the bracket is not an option this time. I timidly attempted putting it on a vise per the manual, but the pulley is still there. Additionally, it does not seem to have the "retaining ring" as the manual indicates, so maybe I am not seeing something... (picture attached) Any hints or direction how to unscrew that evil pulley from the armature is greatly appreciated. For those interested in pictures, I promise that I will be posting them through the entire rebuild process. Thanks!
-Conrad |
01-05-2014, 01:10 AM | #2 |
Re: Early '46 Generator Rebuild
Might want to try some 50-50 Acetone/Transmission fluid soaked into the threads to loosen it up. The pulley does unscrew. That's how I got mine off.
There is a lock ring that goes on the end but I don't know how necessary it is. I don't have one and don't think the pulley could accidently spin off even without it.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
01-05-2014, 10:59 AM | #3 |
i think the lock ring is there to keep the pulley from unscrewing in the event of engine "backfire".
tom |
01-05-2014, 11:18 AM | #4 |
That's brilliant! Henry's engineers thought of everything. DD
01-05-2014, 11:49 AM | #5 |
I had a piece of old belt cut to fill the pulley groove then I put a strap wrench over it, the armature is clamped in a good vice with copper jaw liners ---this worked every time for me.
01-05-2014, 03:10 PM | #6 | |
Thank you for your guidance, the pulley is taking a "bath". Regarding the missing clip, judging for your plus 10,000 miles you put on Old Henry, we should be fine without it.
-Conrad |
01-05-2014, 03:16 PM | #7 | |
Thanks, I will emulate your method. I think that I have the old belt, and if not, have a strap oil filter remover that can be used. The only piece missing are the brass jaws for the vise. I have four of them and none have brass. Maybe Home Depot or Ace Hardware have some generic jaws, or I can buy a strip of brass and cut it to match the jaws size. --c
-Conrad |
01-05-2014, 03:17 PM | #8 |
Backfire? That will mean good news because the engine is spinning on its own power At least it would be a start
-Conrad |
01-05-2014, 04:46 PM | #9 | |
Karl |
01-05-2014, 05:18 PM | #10 |
Kurt,
Thanks. I was not going to make a trip to Home Depot...so I got a piece of copper pipping and cut it to the same length of the end of the armature, and I slid the copper piece. Then, I got the armature perpendicular to the vise jaws and tighten using some "leverage". The force made an oval out of the copper circumference and kept the armature from spinning. Finally, I used an oil strap wrench to remove the pulley (counterclockwise), and got it out. Now I am fighting the bearing... more to come along with pix.
-Conrad |
01-06-2014, 07:36 AM | #11 |
Armature removed from the generator and clamp the body of the armature in the vise. Heat from a propane torch to the collar around the threads.
