07-12-2017, 08:14 AM | #1 |
Where do you store the cranckhandle?
In my tudor is no space to store the crankhandle and jack so i put it behind the seat on the floor.
If my trunk is on the rack i can put it there but the trunk is not always on,only when i go on long runs without a trailer. Where do you put the crankhandle and jack,tools etc.?
It is a pile of shit bit it's my pile of shit |
07-12-2017, 08:35 AM | #2 | |
Re: Where do you store the cranckhandle?
It's not like you use it every day.
31 Tudor 66 Bonneville 57 Chevy pickup 27 T roadster pick up |
07-12-2017, 08:35 AM | #3 |
I though that the Tudor tools were kept under the rear seat? I store mine either in the trunk or under the front seat in my car.
Mike
07-12-2017, 08:57 AM | #4 |
My crank handle is kept under the drivers seat in my tudor. The jack etc. is under the rear seat.
07-12-2017, 09:09 AM | #5 |
I have a jack under the front seat and I found the crank in the floor next to the rumble seat. I'll probably keep both under the front seat.
07-12-2017, 09:13 AM | #6 |
The trunk on the back of the tudor and the roadster are a godsend when travelling with friends in the cars. The biggest challenge I usually find is where to store the jug of coolant, so it doesn't tip over. Jeff
Let's let pylons, be pylons! |
07-12-2017, 09:43 AM | #7 | |
1929 Model A Ford Coupe |
07-12-2017, 10:34 AM | #8 |
Mines under my seat in my Roadster Pickup
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
07-12-2017, 10:37 AM | #9 |
On most models there is room under the front seat. On a tudor there is room under the rear seat.
07-12-2017, 11:21 AM | #10 |
My uncle told me when he was a kid he saw a lot of fights were cranks were used so they must have had them handy! Tough for the T driver
07-12-2017, 11:32 AM | #11 |
Under the rear seat in a tudor ! Just push the lower cushion back, then lift up. If you shocks aren't working, put some padding in there ! :-) Points, plugs, rotor, cap etc, no room for a starter or generator. Someone makes boxes that under the pan under the rear seat, but you have to cut two big holes each side of the drive shaft :-(
07-12-2017, 12:26 PM | #12 | |
http://www.snydersantiqueauto.com/storage-box |
07-12-2017, 12:17 PM | #13 |
In my Tudor the crank is under the drivers seat and the jack is in my back pocket.
Before Walmart you had to buy a ticket to the fair to see a bearded lady! |
07-12-2017, 12:30 PM | #14 | |
Doesn't that make sitting kinda uncomfortable? I stored tools under the seat - small stuff in the pouch and crank and jack wrapped in shop rags to keep from rattling (also good for wiping hands). Course that was a coupe that had a handy under-seat pan for the purpose. How about a toolbox on the running-board? More common on Model T but should work on A - don't think they're reproduced but original examples aren't too uncommon. |
07-12-2017, 12:36 PM | #15 |
Leave the crank behind.
Park on a hill . . . . |
07-12-2017, 03:21 PM | #16 |
My dad wanted my hand crank! because he didn't want me hand cranking.
But dad want if I have a flat and need to put on the spare? Don't hand crank it, if it doesn't break your arm, I will ! Yes I did, many years later, it started right up!
07-12-2017, 05:49 PM | #17 | |
Back the the thread! Crank handles are not readily available so I don't have one in each car. In those I do, it lives under the back seat along with a few other bits and pieces all wrapped in an old towel or similar to stop the clangs when I hit a bump.
07-12-2017, 02:19 PM | #18 |
Not when it's the AAA card and the fellow using his jack and handle are changing the tire!
07-12-2017, 03:14 PM | #19 |
Crank usually sits in the passenger seat.
Always one bad decision away from a good time. |
07-12-2017, 12:30 PM | #20 |
Thanks for correcting me !
