03-31-2014, 07:35 AM | #1 |
oil filter restricked fitting
Where can I get one of those restricked fittings that goes into the side of the oil filter 49-8ba, this one is broken. 1/8 pipe into the can and take the flared 1/4 line fitting. Does anyone have a Dorman no? Thanks Walt
03-31-2014, 08:05 AM | #2 |
Re: oil filter restricked fitting
Walt, it is so easy to solder the hole closed in a standard fitting and then drill it with a 1/16" (.062") drill. Use a little muratic(sp) acid to clean the fitting.
03-31-2014, 08:05 AM | #3 |
I once tapped a fitting and used a carb jet for the restriction ---don't remember what the jet was from, but it got the job done
03-31-2014, 10:00 AM | #4 |
Walt.....I think I saw these for sale in C & G catalog.
03-31-2014, 03:24 PM | #5 |
'52 F-1, EAB flathead |
03-31-2014, 09:07 PM | #6 |
03-31-2014, 09:10 PM | #7 |
03-31-2014, 09:49 PM | #8 | |
Walt it is a #1512 weather head fitting R |
04-01-2014, 05:29 AM | #9 |
Thanks R for that weather head part no. Walt
