Old 08-07-2020, 07:19 PM   #1
46woodie
Default Ford/Zenith radio
Rebuilding radio for the 46. Been told I should switch to a solid state vibrator. Where do you find them. I can find the original ones but nothing solid state.thanks
46woodie is offline   Reply With Quote
Old 08-07-2020, 07:25 PM   #2
corvette8n
corvette8n's Avatar
Default Re: Ford/Zenith radio
https://www.tubesandmore.com/product...tomobile-radio
Try this place I have not done business with them.
Old 08-07-2020, 07:43 PM   #3
46woodie
Thanks for info on the solid state piece. Sounds like a few people had problems with noise after installing them
Old 08-07-2020, 08:00 PM   #4
Merc Cruzer
Merc Cruzer's Avatar
Actually, they are quiet and work perfectly. What you do loose is the hum the vibrator made, and it turns on a bit faster. I miss the hum sound, but that is progress for you.
Merc Cruzer is offline   Reply With Quote
Old 08-08-2020, 06:31 PM   #5
rotorwrench
rotorwrench's Avatar
The solid state vibrator replacements are polarity sensitive so a person needs to know whether they radio set will be run as negative ground or positive ground and what voltage will be used. The units should be available for all contingencies.
This outfit advertises the 4-pin type if that's what it has. They should be plug & play but a person can make one if they have a mosfet transistor & a few other components.
https://www.radiosforoldcars.com/productsF.htm
There are likely other sources as well like the one posted previously.
Old 08-08-2020, 10:20 PM   #6
46woodie
Thanks, 4pin positive ground,6v. I'll look into it,just curious as if it's really worth the change
Old 08-09-2020, 12:12 PM   #7
rotorwrench
Many times the points need to be cleaned in the old vibrators. A lot of them can be brought back to life. They are not polarity sensitive. the old radios needed the higher voltage to make the tubes function properly. Tube type amplifiers have excellent frequency output. A lot of electric guitar players still prefer the old tube type amps to the solid state units. The old capacitors are the things to replace in the old radio sets.
