11-03-2018, 05:39 PM | #1 |
49 tudor filler pipe
Putting trunk in 49 ford. Can someone be find enough to give me some measurements for the filler tube to penetrate the new trunk floor. the car didn't have a trunk floor when I bought it. I'm afraid if I don't have a starting point I'll ruin the new trunk pans.
11-03-2018, 08:23 PM | #2 |
Re: 49 tudor filler pipe
Do you think it would be the same as a '50 coupe?
11-04-2018, 07:53 AM | #3 |
I'm guessing you have no quarter panel on it because installing the filler tube will put it right where it needs to be. To answer above the hole is probably in the same spot but the filler tube is different due to the use of a gas cap door.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
11-04-2018, 08:44 AM | #4 |
I do have the Qtr panel on the car. When I insert the filler tube it will go in about a six inch radius from a center point. A measurement from the side quarter panel to approximately the center of the tube will put me in the ballpark. Thank You.
11-04-2018, 09:25 AM | #5 |
Before welding in the trunk floor install the filler tube to the tank and quarter panel.
Then do the floor using a cardboard template to locate needed hole in the floor. Last edited by 19Fordy; 11-04-2018 at 12:07 PM. |
11-04-2018, 10:09 AM | #6 |
How much of the cars original floor is still useable? Measurements can be given but the accuracy may vary somewhat from car to car. This is especially true if there was ever some frame bending or movement off plumb from original position. The hole is an ellipse so it will have to be clocked correctly too. If it's off, weld in a piece to correct it. Start with a small hole. It's easier to correct that way if it's off. The rubber grommet that fits there may also be a help for size. You would be hard pressed to ruin a floor pan. It's easy to fix any mistakes by just welding it up & starting over. Last edited by rotorwrench; 11-04-2018 at 10:14 AM. |
11-04-2018, 11:44 AM | #7 |
I have a 49 4dr. I will send you pics and measurements later today. Not sure if it exactly like the 2 Dr.
Sent from my iPhone using Tapatalk |
11-04-2018, 02:29 PM | #8 |
M...........on my '50 coupe it is 11" from the quarter panel to the middle of the filler neck and 12 1/2" from the rear of the the car to the filler neck to where it goes thru the the floor pan. I believe '49 and '50 gas tanks are the same. Hope this helps.
11-05-2018, 09:27 AM | #9 |
Thanks to all! 50fordcoupeman that's what I needed. For information purposes the gas tank mounts to the floor pan and the trunk floor is three piece EMS. Again Thank You All.
