12-28-2018, 11:29 PM | #1 |
Redoing Brakes
These days, how much does it cost to redo your whole brake system (original way) including cast iron drums? My brakes on my AR feel good but I was warned that they need to be completely rebuilt.
12-29-2018, 12:06 AM | #2 |
Re: Redoing Brakes
I was recently quoted $500 a wheel, my 30 pickup truck has original style brakes/parts, do not remember if parts/drums were upgraded parts/replacements. Shoes and drum were in OK but worn shape, so we decided to scuff up the shoes and have the place adjust as good as they can. Did not have $2000 in the bank to spend on this. Looks like I will have to save up the money.
12-29-2018, 07:47 AM | #3 |
Re: Redoing Brakes
$2000 is a reasonable estimate if you choose to do most of the work yourself. If you are hiring someone to 'turn-key' the work for you, generally speaking between $3,300-$3,500 to do everything. There is a lot of work to restore everything on an early Model-A (-no such thing as an AR Model-A) as some of the components are unavailable and must be restored instead of replaced.
12-29-2018, 09:11 AM | #4 | |
Re: Redoing Brakes
As an fyi, they quoted 8 hrs labor per wheel. This was for a late 30, and do not think it included new backing plate assemblies. For the work we agreed on
12-29-2018, 09:16 AM | #5 |
Re: Redoing Brakes
Contact Randy Gross.
12-29-2018, 11:10 AM | #6 |
Re: Redoing Brakes
12-29-2018, 02:31 PM | #7 | |
Re: Redoing Brakes
Does Mr. Gross also rebuild brake shaft housings, brake cross-shafts, rebush the pedal, install tracks on plates, center/arc the shoe linings, etc. for a hobbyist to rebuild their entire system? |
12-29-2018, 02:38 PM | #8 |
Re: Redoing Brakes
Be are to start any conversation with the fact that you have an "AR" system which I assume you want to retain. I think you are going to find that most parts are for the later systems.
Charlie Stephens |
12-29-2018, 02:50 PM | #9 |
Re: Redoing Brakes
When I had Randy do my brakes, I sent him everything from the backing plate out. Everything came back like it was new from the factory with cast drums. He does all the other things that you mentioned but since those had been done previously and were in good condition, I didn’t have them done.
12-29-2018, 03:09 PM | #10 | |
Re: Redoing Brakes
Thank you. Was just curious. |
12-29-2018, 03:56 PM | #11 |
Re: Redoing Brakes
I would like to keep the AR system but the struggle I have with it is that the emergency brake does not run independently from the brakes, which I do not like for safety reasons. Though I suppose if the system was completely rebuilt you would not have to worry about failures.
12-29-2018, 05:09 PM | #12 |
Re: Redoing Brakes
Scuff shoes? Please explaine.
12-29-2018, 05:11 PM | #13 |
Re: Redoing Brakes
I just redid the brakes on my 30 CCPU myself and the figure of $2000 is way too high. If you are any kind of mechanic, the parts will cost you: 4 cast iron drums = $1000, 8 new brake shoes= $256 and some odd and ends= $100. Your labor is not included and that includes arcing the shoes yourself (not that complicated). My truck will now stop as good as any car with non-power assisted brakes.
AL in NY |
12-29-2018, 05:19 PM | #14 |
Re: Redoing Brakes
12-29-2018, 06:14 PM | #15 |
Re: Redoing Brakes
If you buy new drums and relined shoes see if you can get the person you buy them from to arc them.
Charlie Stephens |
12-29-2018, 06:15 PM | #16 |
Re: Redoing Brakes
12-29-2018, 06:19 PM | #17 | |
Re: Redoing Brakes
The $2000 included labor to have it done, I am not a mechanic. Well worth it to me having someone familiar do it correctly, than for me to try to learn how and mess it up. |
12-29-2018, 07:48 PM | #18 | |
Re: Redoing Brakes
I usually tell customers that typical comprehensive brake jobs run approximately 30-40 hours labor. I use cast iron drums and bonded soft lining and replace parts as they warrant. Bushings, shafts, all levers pins cross shaft and all are part of the brake job. I use Randy’s drums and have had good success and he is super. I will add that here is lot more to doing a brake job than just getting your assemblies from one of the supplies that provides that service. Unless you are schooled at adjustment , brake cross shafts pedal to drums I think that it is a process of a complete job that if I were a cuStomerI would rather have a guy like myself or Brent doing the job. I understand there are many areas where there isn’t a mechanical restorer resident so that is another case . Your early AR brake system has its non standard complexity as well. Cost wise for labor outsourced and parts you are looking at $3k to 3500 which I believe is about what Brent said. Parts only about $1300-1500ish give or take depending on what’s uncovered . Also, many times while the brakes are down there are other issues uncovered that need attention. Front end work, steering boxes, rear axle, spring shackles etc. you may have issues with many of these but not know it and they of course aren’t covered with core replacements by mail order. Restored properly and adjusted properly the model abraded can stop on a dime. All my customers are always happy with my brakes and know especially if they are local they have brake adjustments for life from me. Of course that’s my life ! Brakes, front ends, etc are not brain surgery but there is experience and process and standards that make the difference between a poor system and a well restored system and car. All the best for 2019! Larry Shepard Last edited by larrys40; 12-29-2018 at 07:59 PM. |
01-01-2019, 08:30 AM | #19 | |
Re: Redoing Brakes
what is the story behind the "pill" sometimes used on the front mechanism? Surely that is not original... |
01-01-2019, 09:26 AM | #20 | |
Re: Redoing Brakes
We have actually seen vehicles come to have brakes restored that had multiple 'pills' stacked on each other trying to compensate for worn parts. If you have the need to use these 'pills', you really need to find the item(s) that are out of specification. The first place I would suggest is the operating pin itself. |
