08-22-2010, 04:13 PM | #1 |
update on stuck valve
Thanks all for the advice. I took the side plate off to check the valve and the #3 exhaust was not stuck but adjusted too tight. I set the clearance but still no compression. I think it is burned and will need replaced.
The engine has 5500 miles on it and I now realize that I should have checked the valve clearance after it broke in. This is good news though. In July we took a 1300 mile trip from Illinois to Vicksburg Ms. We had no mechanical problems the whole trip.My Tudor deserves a little TLC,after such a fun trip. |
08-22-2010, 04:55 PM | #2 |
Re: update on stuck valve
