01-15-2019, 05:05 PM | #21 |
Re: Ignition, way of
If you want some excellent shocks that look close to original, but are sealed and very well made, consider Stipe Shocks at the link below. I had mine tested and they came very close to original specs. Not cheap, but really good. If you want originals, that will be a bigger challenge.
http://specialtymotorcams.com/shop.php
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930. |
01-15-2019, 05:30 PM | #22 |
Hello Kim,
thank you for the link to Mr. Stipe. Yesterday I contacted him for deliver time and shipment etc.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
01-16-2019, 09:41 AM | #23 | |
Stipe shocks are NOT SEALED ... The plug can be removed and shocks refilled. At least that is true of the two sets that I bought. |
01-16-2019, 09:48 AM | #24 |
... deleted duplicate post
01-16-2019, 12:57 PM | #25 |
Benson, Thanks for the clarification.
Yes, I was generalizing. You can add fluid, but they don't leak, so it is "sort of" sealed? They can be adjusted for winter, summer. I like the look and feel of them. A quality product for a 90 year old car.
01-16-2019, 01:05 PM | #26 |
I think there are 'Simmerings' mounted. I understod there gets no oil outside. These shocks must be leekproof.
01-22-2019, 04:08 PM | #27 |
Hello,
Stipe's shocks are on the way. Ignition; I have the hand lever slightly narrower filed and also the lower limit on the teering. I shortened the connecting rod to the distributor a bit. Now my adjustment is -5 > +35 degrees. I think, that is enough. Not really true, but it's a solvent. Thanks at all for the helping hints!
01-26-2019, 03:00 PM | #28 |
Hello,
I have now solved the problem unusually. The previous adjustment also went with tricks (rod angle) not exceeding 30 °. Now I have on the hand lever the lower downend to the stop plate filed a little slimmer. And also the stop plate ground down a bit. Now I have an adjustment of about -5 to +35 degrees. Thank you for the helping hints to the ignition adjustment by hand!
