Old 03-21-2018, 11:36 AM   #1
talwrench
Default generator brush install
In rebuilding the generator which way do the brushes get installed. with tapered end of the brush with the rotation or towards it? Another way of stating it would be should the long end of the brush be toward the side of the communtator when the comutator is passing the brush, of should the long end be facing the communtator as it enters the brush? Thanks Tim
talwrench is offline   Reply With Quote
Old 03-21-2018, 12:26 PM   #2
1930-Pickup
Default Re: generator brush install
Be sure that the section of the brush with the slight radius sits flush onto the commutator for maximum contact.
For best performance the brushes should be ground to match the commutator.
The thinner brush fits in the third brush (adjustable) position.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 03-21-2018, 01:04 PM   #3
Crankster
Crankster's Avatar
Brushes should be sanded so as to present a full contact patch with the commutator before use otherwise they will most likely burn. Every generator manual illustrates this.
Crankster is offline   Reply With Quote
Old 03-21-2018, 03:16 PM   #4
talwrench
Thanks for the tips!! Tim
Old 03-21-2018, 10:56 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
The shorter side of the brushes always faces the brush holder pivot post.
2 thick brushes for power, and the one thinner brush is for the adjustable field wire.
Old 03-22-2018, 08:40 AM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
In an emergency, putin' brushes in my '49, pardon the expression, "CHEVY", we sat & "custom" ground them on the Cement Curb!
Bill Improviser
"THE ASSISTANT GURU OF STUFF"
Old 03-22-2018, 10:52 AM   #7
talwrench
Thanks TOM that is the info I was looking for. Tim
