09-16-2015, 03:29 PM | #1 |
Light switch diagram
DOES ANYONE HAVE A PICTURE OR DIAGRAM OF A 39 OR EARLY LIGHT SWITCH @ THE BOTTOM OF THE STEERING COLUMN , IT IS NOT IN THE GREEN BIBLE thanks SUNSHINE
09-16-2015, 03:32 PM | #2 |
Re: Light switch diagram
I have a 39 but no switch at bottom of steering col. Do you mean the dash dimmer switch?
09-16-2015, 03:42 PM | #3 |
There is a light switch at the end of your steering columns. It is held on by a hard wire bale. Someone will post a photo, sorry I can not.
09-16-2015, 04:34 PM | #4 |
What's it turn on?
09-16-2015, 04:50 PM | #5 |
Actually the light switch is on the opposite end of the steering gear box from the column.
09-16-2015, 05:14 PM | #6 |
09-16-2015, 06:33 PM | #7 |
I can't see the pics, DD
Am I doing something wrong? |
09-16-2015, 09:02 PM | #8 |
I know what the switcrh does . I just want to know if I have put together correctly ,ITWORKS ,BUT I HAVE A SHORT SOMEWHERE. ADILIO YOU DONT KNOW WHAT THE KNOB IN THE MIDDLE OF YOUR STEERING WHEEL DOES you must have a modified car SUNSHINE
09-16-2015, 09:17 PM | #9 |
I know what the switch does , I just want to know if I have everything put together correctly .I have it working but I have a short somewhere . D.D.thank you for pictures,but they dont show the actual switch. adilio you must have a modified car if you dont have this switch SUNSHINE
09-16-2015, 09:59 PM | #10 |
These are NOT 39 Ford light switch parts, but all of the early Ford light switches are similar in construction. If I remember correctly you were having a problem with power remaining on when the switch was in the off position. I would start by checking of a short between any of the connections on the plate that the wires connect to. Then I would check to assure that the contact plate than moves with the wheel switch to the correct positions including the off position.
The 39 light switch is wired such that the high beam/low beam is selected by a separate floor foot operated switch. Last edited by JSeery; 09-16-2015 at 10:08 PM. |
09-17-2015, 06:07 AM | #11 |
I have a stock banjo with headlight switch in steering wheel. What threw me was you first post said bottom of steering column and no mention of headlights.
All good coop & seery explained it well |
09-17-2015, 06:16 AM | #12 |
I believe the wiring diagram above and below is what you need. The most often problem with the switch wiring is having one of the wires on the switch move and touch another or the cover.
09-17-2015, 07:08 AM | #13 |
Thanks Jseery for the pictures andTerry OH for the wire diagram , but my problem is FUSE 30 AMP getting very hot and blowing when hd. lights are turned on NEW WIRE HARNESS , NEW SWITCH AND 6V SEALED BEAMS. THANKS SUNSHINE
09-17-2015, 08:19 AM | #14 |
I believe that "Fuse" should be 20.A not 30. The fuse should be instantaneous and not "Slow-Blow" or time delay. Is the fuse blowing with the lights in the "off" position or just when "on"?? is the switch for the pillar lights on or off?
I suggest turning the lights off. replace the fuse with a 20. Amp. then test the pillar lights only to see if they work, or blow the fuse, if OK turn them off. Then step on the brake pedal, do the brake lights work properly? if so that part of the circuit is good. take your foot off the brakes. Then turn the light switch to the parking position, if the fuse blows, the problem lies in just the parking lights if it doesn't that part of the circuit is OK. Continue until you eliminate the good circuits and find the circuit that is bad. Just my guess "Sealed beam" headlights are too much of a load and are blowing the fuse especially in the country beam position of the light switch. You may not have a problem with the wires. |
09-17-2015, 03:49 PM | #15 |
Terry , OH THANK YOU I have eliminated every thing except the hd. lites , fuse only blows when the hd. lites are turned on , everything else off. The man who made my new harness said he uses the same gauge wire for 40 fords and up that had sealed beams. this truck was converted years ago to sealed beams. I even tried the old sealed beams , same result.THIS IS PROBLEM IS THE FUSE GETS VERY HOT BEFORE IT BLOWS 20 amp would blow for sure. THANK YOU
09-17-2015, 03:56 PM | #16 |
Next, disconnect 1 headlite at a time and check again
You may also have a bad ground |
09-17-2015, 05:22 PM | #17 | |
Hey, attached is a diagram that I feel is easy to follow. Sorry the scan is poor. It's the best I have. Hope it helps.
09-18-2015, 04:40 AM | #18 |
Kube thank you for the diagram , that is the same one I got with my TYREE wire harness. I am going to try replacing my hd. lite bucket grounds THANK YOU SUNSHINE
09-18-2015, 08:43 AM | #19 |
Your best bet would be to isolate the problem as suggested by several posters above. Need to determine what is causing the excess current draw.
09-18-2015, 08:51 AM | #20 |
Sunshine, Try checking the fuse clips to see if they are making good contact with the fuse. Sometimes the clips expand or oxidize and do not make good contact.
