Old 11-03-2017, 03:59 PM   #1
Jwilli
Jwilli's Avatar
Default Electronic Ignition
I just got a 1930 Cabriolet. It has the Pertonix ignitor 6 volt pos ground.I would greatly appreciate if one of you more experienced Model A lovers could point me to a site that explains how to check it out. Thanks in advance.
Jwilli is offline   Reply With Quote
Old 11-03-2017, 04:23 PM   #2
duke36
Default Re: Electronic Ignition
Try FS ignitions in Oklahoma on line. They have similar instructions or try the Pertronix web site.
Old 11-03-2017, 05:05 PM   #3
Jim/GA
Jim/GA's Avatar
How to check it out?
It either works and the engine runs or it doesn't.
What else do you want to know?
Jim Cannon
"Have a Model A day!"
Old 11-03-2017, 05:27 PM   #4
Dave in MN
Dave in MN's Avatar
Pertronix has installation sheets for their various modules.
http://www.pertronix.com/prod/ig/default.aspx
FYI: If you are or ever do experience any trouble with these electronic modules, the first thing to check is that it has a good ground connection.
Like Jim said...either works or it doesn't.
Good Day!
Dave in MN is offline   Reply With Quote
Old 11-03-2017, 06:09 PM   #5
Jwilli
Jwilli's Avatar
Thanks Duke, I found the instructions for bench testing. I appreciate your help.
Old 11-03-2017, 07:30 PM   #6
glenn in camino
glenn in camino's Avatar
I gave up on my electronic distributor and went back to the stock system. Now my model A runs better than ever, plus I now have control of the spark on hills.
Old 11-03-2017, 09:23 PM   #7
denis4x4
denis4x4's Avatar
With all do respect to Glenn in Camino, the Per-Lux Ignitor, Petronics and now the FS have been around for 35 years. Created to run stationary engines 24/7, the electronic ignitions are pretty much bullet proof. Unlike others here, I will admit my FS failure was self inflected due to not following directions. I have used these ignitions in classic cars, a 1942 Chris-Craft, Catalina 30 inboard and four Model A's without any issues.
Mickey Remund (engine builder for Mickey Thompson) perfected the Petronix for Model A's and early Ford V-8's and sold the business to FS when he retired.
As others have noted, call FS for info.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 11-04-2017, 07:10 AM   #8
Frank Miller
Frank Miller's Avatar
I'm running a pertronix on my 49 for 3 years now. Just did an 8100 mile trip. 6 volt pos grnd
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 11-04-2017, 04:34 PM   #9
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I have 33,000 plus on my 6 V remund
Old 11-04-2017, 05:42 PM   #10
Dave in MN
Dave in MN's Avatar
I just passed 90,000 on my Nu-Rex this Fall while on a road trip. Only issue I have ever had was a weak ground connection.
Good Day!
Old 11-04-2017, 06:12 PM   #11
AL in NY
AL in NY's Avatar
Best ignition system for a Model A. Install it and forget it. You never have to worry about point gap and timing again. Have had mind for 9 years and 13,000+ miles and have yet to adjust the timing.
AL in NY
AL in NY is offline   Reply With Quote
Old 11-04-2017, 06:50 PM   #12
Jwilli
Jwilli's Avatar
I found the problem today. A wire was loose in one of the lugs. Used a new lug and crimped properly. It now runs great.
