Old 12-14-2019, 12:39 PM   #1
tommyleea
Default 55 F100 Front brake lines
Front brake lines missing off my truck. I am making new ones. Do the brake lines run through the holes in the frame crossmember? Looks like they would, but probably need grommets in the holes? Thanks..
tommyleea is offline   Reply With Quote
Old 12-14-2019, 01:02 PM   #2
Ole Don
Ole Don's Avatar
Default Re: 55 F100 Front brake lines
The usually don't go through holes, they are clamped on top of the left frame rail, then to the back of the crossmember to the right side.
Ole Don is offline   Reply With Quote
Old 12-14-2019, 03:11 PM   #3
tommyleea
Thanks..that makes more sense..
Old 12-14-2019, 08:41 PM   #4
KULTULZ
KULTULZ's Avatar
Post Re: 55 F100 Front brake lines
Originally Posted by tommyleea View Post
Do the brake lines run through the holes in the frame cross-member?
Through the front of the frame rails. Holes in the rails?
So, I asked the wife, ‘Where would you want to go for our anniversary?’
It so warmed my heart to see her face melt in sweet appreciation ...
‘Somewhere I haven’t been in a long time!’ she said.
So I suggested, ‘How about the kitchen?’
And that’s when the fight started ....
KULTULZ is offline   Reply With Quote
Old 12-15-2019, 10:00 AM   #5
tommyleea
Not in the rails, but in the crossmember. There is a hole on each end of the crossmember that would line up just right for the brake lines. But, as stated earlier, probably not the way to go. Thanks for the diagram...
Old 12-15-2019, 10:26 AM   #6
KULTULZ
KULTULZ's Avatar
Question Re: 55 F100 Front brake lines
Old 12-20-2019, 12:46 PM   #7
bobss396
bobss396's Avatar
You should still have the clip-nut holes in the frame and I know the clips are available. I'm getting lazy in my advanced years and try to use lines with the fittings already on them.
bobss396 is offline   Reply With Quote
Thread Tools
Display Modes
