Old 11-17-2019, 08:38 PM   #1
37 Coupe
37 Coupe's Avatar
Default Rubber pads for tail lamp and head lamp stands.
I searched and see that most do not like using the aftermarket rubber pad between the stand and fender.Is that also the general consensus about using pads on the headlamp bar to fender? Mainly concerning grounding issues.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 11-18-2019, 11:10 AM   #2
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Rubber pads for tail lamp and head lamp stands.
I use one layer of clear shipping tape cut to the shape of the foot print to protect the paint. Works well and cannot be seen. It is also very inexpensive.
Bob Bidonde
Old 11-18-2019, 11:15 AM   #3
Badpuppy
Pads protect the paint. Paint doesn't conduct anyway. If grounding is your concern, run a wire between each headlight conduit and the forward hood latch screw. Hose clamp at conduit and #10 ring lug (solder) and star washer at the other end.
