Old 12-10-2019, 11:44 AM   #1
Flyboy1st
Default Rear axel
What tool fits the two drain plugs on the rear-end?
Flyboy1st is offline   Reply With Quote
Old 12-10-2019, 11:50 AM   #2
aford193031
aford193031's Avatar
Default Re: Rear axel
I have not looked at mine for a while but believe that a 3/8” drive fits.
aford193031 is offline   Reply With Quote
Old 12-10-2019, 02:21 PM   #3
Synchro909
Synchro909's Avatar
They are the same plugs that old time plumbers used.
Just strap a Model A to your backside and go.
Old 12-10-2019, 05:31 PM   #4
J Franklin
J Franklin's Avatar
Originally Posted by aford193031 View Post
I have not looked at mine for a while but believe that a 3/8 drive fits.
I use 3/8" breaker bar.
Old 12-10-2019, 05:51 PM   #5
Purdy Swoft
Purdy Swoft's Avatar
I just use a 3/8s ratchet .
Purdy Swoft is online now   Reply With Quote
Old 12-10-2019, 05:51 PM   #6
CWPASADENA
CWPASADENA's Avatar
There was a special combination tool available that would fit the different size square holes in drain plugs that most service stations had however, as other previously have stated, for the Fords, a 3/8 breaker bar works just fine.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 12-11-2019, 12:31 AM   #7
mleder
a 3/8 breaker bar will work , although it is a sloppy fit. If the square gets rounded off and it's real tight you may not get it out. If you want to keep that plug hole square buy a piece of "key stock" at a bearing house that measures 7/16" square. This is a very stock item and you can buy a small section and cut it up and give it to your friends as a present. Either grip it with a 7/16" wrench or better yet weld a hex nut on the end of it and use a socket on it
mleder is offline   Reply With Quote
Old 12-11-2019, 09:30 AM   #8
rocket1
Model A monkey wrench end has the square that fits the plugs in the rear,find them in the flea market,some are script.
rocket1 is offline   Reply With Quote
Old 12-11-2019, 10:20 AM   #9
Flyboy1st
Thanks, you have all been a good help. I have a 1929 45A coupe, a lot of original stuff on it. I always seen 3/8 on both plugs but on this coupe 3/8 just catches but slips when I apply pressure, looks like it is 7/16.
